Installing new Rubber Engine Compartment Seals, What to lubricate them with |
euro911 |
Jan 12 2012, 11:30 AM
Retired & living the dream. God help me if I wake up! Group: Members Posts: 8,851 Joined: 2-December 06 From: So.Cal. & No.AZ (USA) Member No.: 7,300 Region Association: Southern California |
Since the drive train is out and Milt fixed the engine shelf in my '75, I'm getting ready to install new [914rubber.com] seals around the engine compartment.
The old ones were hard and brittle (what was left of them), and I had to bend the rails on the slots apart a little to get them out. What do you guys use to lubricate new seals so they don't bind or tear when pulling them in? (IMG:style_emoticons/default/popcorn[1].gif) |
SLITS |
Jan 12 2012, 11:32 AM
"This Utah shit is HARSH!" Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Sliicone spray or soapy water
JeffBowlsby |
Jan 12 2012, 11:39 AM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
I use glycerin from the drugstore. Preserves rubber items too.
andys |
Jan 12 2012, 12:25 PM
Advanced Member Group: Members Posts: 2,165 Joined: 21-May 03 From: Valencia, CA Member No.: 721 Region Association: None |
K-Y Jelly from the drug store works great; been using it for years......for AUTOMOTIVE purposes :-)
Andys |
aharder |
Jan 12 2012, 12:33 PM
Advanced Member Group: Members Posts: 4,410 Joined: 6-September 11 From: Dallas Texas Member No.: 13,524 Region Association: Southwest Region |
K-Y Jelly from the drug store works great; been using it for years......for AUTOMOTIVE purposes :-) Andys (IMG:style_emoticons/default/agree.gif) I've been using it for years also.... But not just Automotive!! (IMG:style_emoticons/default/biggrin.gif) |
euro911 |
Jan 12 2012, 12:43 PM
Thanks. I didn't want to introduce [soapy] water into the slots (don't want anything to start rusting in there), so glycerin or KY sounds like a pretty good way to go.
Then, it seems that glycerin, or KY, would also work for rubber [suspension] bushings? ... I'll be replacing the front bushings and installing an anti-sway bar soon as well ... |
ellisor3 |
Jan 12 2012, 02:15 PM
HPWhore Group: Members Posts: 811 Joined: 23-October 08 From: Fleming Island, Florida Member No.: 9,683 Region Association: South East States |
WD 40 also works well and helps displace water, much like the other things listed. WD 40 may be easier to apply though.
geniusanthony |
Jan 12 2012, 02:51 PM
Its a brand new "Chrome-sicle" Group: Members Posts: 517 Joined: 12-December 05 From: Alexandria,VA Member No.: 5,266 Region Association: MidAtlantic Region |
From the reading I have been doing, Silicone based lube is bad for rubber items, As Jeff said.. I second Glycerin or Glycol is another name for the stuff. Works great for preserving rubber also. BMW spares product called Gummi Pfledge(sp) is also a good preservative as an FYI.
rwilner |
Jan 12 2012, 02:53 PM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
I lubricated mine with simple green, which is also what I was using to clean up the engine compartment. Worked great
bandjoey |
Jan 12 2012, 06:26 PM
bandjoey Group: Members Posts: 4,926 Joined: 26-September 07 From: Bedford Tx Member No.: 8,156 Region Association: Southwest Region |
Stop and do NOT pass go. 914rubber.com recommends an Aero product I forgot the name of.........My bottle is at home and I'm at work. It not only cleans it protects for a long time.
Mark?? And he is the imperial potentate of 914 rubber. |
toolguy |
Jan 12 2012, 07:10 PM
Senior Member Group: Members Posts: 1,270 Joined: 2-April 11 From: San Diego / El Cajon Member No.: 12,889 Region Association: Southern California |
OK here is the best product to use. . . It's called 'Smoothie'. . it's a painters product and is actually liquid silicon. .It's only available at profession auto painter supply stores. . . it is also a rubber preservative beside being slippy. . . it' will protec also. . . . it is absorbed into the the rubber. . . it's around $15 for 8 ounces and is clear. . . it also leaves a great sheen on the rubber. . think Armor all. .only this is good stuff. .
here's a link. . . http://solutions.3m.com/wps/portal/3M/en_U...Rgl6V675XC7QXbl |
McMark |
Jan 12 2012, 08:37 PM
I guess I'm the only one who just installs them by setting the seal in the lower lip and pushing the seal under the top lip with a flat screwdriver. I never much liked sliding seals into place unless there is no other option.
dlee6204 |
Jan 12 2012, 08:44 PM
Howdy Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
I guess I'm the only one who just installs them by setting the seal in the lower lip and pushing the seal under the top lip with a flat screwdriver. I never much liked sliding seals into place unless there is no other option. (IMG:style_emoticons/default/agree.gif) That's the way I do it. |
rick 918-S |
Jan 12 2012, 08:46 PM
Hey nice rack! -Celette Group: Members Posts: 20,492 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region |
I guess I'm the only one who just installs them by setting the seal in the lower lip and pushing the seal under the top lip with a flat screwdriver. I never much liked sliding seals into place unless there is no other option. (IMG:style_emoticons/default/agree.gif) I use a stiff plastic glazers stick or a rounded flat blade screw driver. I don't like to use anything in my shop that could eventually cause a problem with the painting process. If you come in my shop with silicone I will first beat you then get a restraining order to keep you 300 ft from my property. |
markb |
Jan 12 2012, 09:30 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
I guess I'm the only one who just installs them by setting the seal in the lower lip and pushing the seal under the top lip with a flat screwdriver. I never much liked sliding seals into place unless there is no other option. (IMG:style_emoticons/default/agree.gif) I use a stiff plastic glazers stick or a rounded flat blade screw driver. I don't like to use anything in my shop that could eventually cause a problem with the painting process. If you come in my shop with silicone I will first beat you then get a restraining order to keep you 300 ft from my property. (IMG:style_emoticons/default/agree.gif) |
bigkensteele |
Jan 12 2012, 09:47 PM
Major Member Group: Members Posts: 2,197 Joined: 30-August 04 From: Cincinnati, OH Member No.: 2,660 Region Association: South East States |
I guess I'm the only one who just installs them by setting the seal in the lower lip and pushing the seal under the top lip with a flat screwdriver. I never much liked sliding seals into place unless there is no other option. (IMG:style_emoticons/default/agree.gif) I use a stiff plastic glazers stick or a rounded flat blade screw driver. I don't like to use anything in my shop that could eventually cause a problem with the painting process. If you come in my shop with silicone I will first beat you then get a restraining order to keep you 300 ft from my property. (IMG:style_emoticons/default/agree.gif) (IMG:style_emoticons/default/agree.gif) I agree with all those that agree. I just installed a set of Mark's seals, and no lubricants were required. The rear seal is a little tough in the bends, but not bad. Just use a flat plastic pushing device to tuck the seal in. The toughest part of the project was "mitering" the front corners so they would make a nice joint when the engine is in and the bottom of the seals are tucked up under the tin. |
Elliot Cannon |
Jan 12 2012, 10:59 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
(IMG:style_emoticons/default/agree.gif) What with they all said. Put the lower lip in and I think I used a small putty knife to work the top lip in.
John |
Jan 12 2012, 11:12 PM
member? what's a member? Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
When I lubricate rubber parts for assembly, I use P-80 rubber lubricant. It is formulated as an assembly lube and does not damage rubber.
By the way, WD40 contains no silicone. I also push the engine shelf seals in with a small flat blade screwdriver. |
euro911 |
Jan 12 2012, 11:14 PM
Good suggestion, I'll give that a whirl ...
Thanks for all the replies (IMG:style_emoticons/default/beerchug.gif) |
914_teener |
Jan 13 2012, 05:39 PM
914 Guru Group: Members Posts: 5,205 Joined: 31-August 08 From: So. Cal Member No.: 9,489 Region Association: Southern California |
Good suggestion, I'll give that a whirl ... Thanks for all the replies (IMG:style_emoticons/default/beerchug.gif) You can put them in upside down real easily........ Then you feel like using the KY (IMG:style_emoticons/default/chair.gif) (IMG:style_emoticons/default/av-943.gif) |
Lo-Fi Version | Time is now: 8th June 2024 - 07:19 AM |
