Oil Pump Questions, before I F up |
76-914 |
Jan 13 2012, 06:36 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Apparently, one of the two 4 hole oil pump gaskets is not available. I believe it is the thinner of the two. Henceforth my question. Can I use 2 of the thick ones in lieu of a thick/thin combination. Or can I use this Curil T sealant in place of the thin gasket. Also, I read that the Melling pump drive needs to have 1mm trimmed from the end. I don't know if the one I have has been ground down yet? How long is that tang when new? (IMG:style_emoticons/default/sawzall-smiley.gif) tia, kent
Mark Henry |
Jan 13 2012, 08:37 PM
First I'll give you my opinion of melling pumps.... (IMG:style_emoticons/default/stromberg.gif)
The thick gasket goes under the pump and the thin between the pump and cover. Most bug shops should have both gaskets, if not a type one gasket kit is only about $10. You can adjust the length of the shaft with a press (or vice) the gear is just pressed on the shaft. The modification is most likely to the pump body, as on the T1 VW pumps it hits the cam bolts. You can slightly round the drive shaft tang so it sits down deeper in the cam slot. |
76-914 |
Jan 13 2012, 09:09 PM
First I'll give you my opinion of melling pumps.... (IMG:style_emoticons/default/stromberg.gif) The thick gasket goes under the pump and the thin between the pump and cover. Most bug shops should have both gaskets, if not a type one gasket kit is only about $10. You can adjust the length of the shaft with a press (or vice) the gear is just pressed on the shaft. The modification is most likely to the pump body, as on the T1 VW pumps it hits the cam bolts. You can slightly round the drive shaft tang so it sits down deeper in the cam slot. IIRC, the article I read said the puts a side load on the cam bearings but rounding it sounds better. The OEM style that I originally installed is just a hair low for me. I had a couple of older mellings and got one good one out of it. I'm also going to look at the relief valves before I close it up. Thanks for all of the good info, Mark. |
Lo-Fi Version | Time is now: 9th June 2024 - 04:23 AM |
