Apparently, one of the two 4 hole oil pump gaskets is not available. I believe it is the thinner of the two. Henceforth my question. Can I use 2 of the thick ones in lieu of a thick/thin combination. Or can I use this Curil T sealant in place of the thin gasket. Also, I read that the Melling pump drive needs to have 1mm trimmed from the end. I don't know if the one I have has been ground down yet? How long is that tang when new? tia, kent
