Oil Pump Questions, before I F up |
76-914 |
Jan 13 2012, 06:36 PM
Apparently, one of the two 4 hole oil pump gaskets is not available. I believe it is the thinner of the two. Henceforth my question. Can I use 2 of the thick ones in lieu of a thick/thin combination. Or can I use this Curil T sealant in place of the thin gasket. Also, I read that the Melling pump drive needs to have 1mm trimmed from the end. I don't know if the one I have has been ground down yet? How long is that tang when new? (IMG:style_emoticons/default/sawzall-smiley.gif) tia, kent
Lo-Fi Version | Time is now: 18th May 2024 - 05:39 AM |
