Anyone running dual Weber 34's?, What jet sizes are you using at sea level? |
billh1963 |
Jan 15 2012, 07:28 AM
Car Hoarder! Group: Members Posts: 3,402 Joined: 28-March 11 From: South Carolina Member No.: 12,871 Region Association: South East States |
The '74 2.0 I bought from Utah isn't running so great at sea level. It has dual Weber 34's and I'm sure they need to to be rejetted. Anyone running these carbs who can share their jet sizes?
Outbackskip |
Jan 15 2012, 07:45 AM
Newbie Group: Members Posts: 13 Joined: 13-December 11 From: Gassel, The Netherlands Member No.: 13,893 Region Association: Germany |
The '74 2.0 I bought from Utah isn't running so great at sea level. It has dual Weber 34's and I'm sure they need to to be rejetted. Anyone running these carbs who can share their jet sizes? Hi there, I'm also running Weber 34 ICT's, but mine are on a 1,8. I have the standard jetting setup, the same you can find on the PDF at racetep.com (http://www.racetep.com/weber/34_ICT.pdf). My '74 1.8 runs fine and I'm pretty close to sea level in The Netherlands, maybe as close as anyone can get without getting wet. (IMG:style_emoticons/default/lol-2.gif) Later Skip |
billh1963 |
Jan 15 2012, 10:56 AM
Thanks, Skip. I've read different opinions on whether the 34 is enough carb. I have a line on a pair of Dellorto 40's. I also just bought a complete FI system from a running 2.0 engine. I would like to try to get these 34's tuned right first...and see if they can be made to run right before I looks at other options. I guess I'll use the chart and start from there.
rmital |
Jan 15 2012, 11:43 AM
Northeast optimist Group: Members Posts: 1,947 Joined: 12-December 05 From: Park Ridge, NJ Member No.: 5,268 |
Thanks, Skip. I've read different opinions on whether the 34 is enough carb. I have a line on a pair of Dellorto 40's. I also just bought a complete FI system from a running 2.0 engine. I would like to try to get these 34's tuned right first...and see if they can be made to run right before I looks at other options. I guess I'll use the chart and start from there. I know of a few 914er's in my area running the 34ICT set up. They seem to be keeping up with the rest of us just fine. I just put them on a 74 2.0L and trying to get them dialed in. with little effort so far they do fine. I'm sure I'm missing something basic and I'll be good to go. (by just advancing my timing they improved, just need to get some time to get it perfect) |
Outbackskip |
Jan 16 2012, 12:57 PM
Thanks, Skip. I've read different opinions on whether the 34 is enough carb. I have a line on a pair of Dellorto 40's. I also just bought a complete FI system from a running 2.0 engine. I would like to try to get these 34's tuned right first...and see if they can be made to run right before I looks at other options. I guess I'll use the chart and start from there. One other thing I should mention is that I have a balance tube installed between the 2 34's on the intake manifolds. Some of our Dutch 914-club members also have trouble tuning them in right, but don't have the balance tube installed. My little teener runs so nice and smooth that I don't want to change a single thing on them. Always starts 1st kick, let the fuelpump build up a little pressure, one step on the throttle and away she goes. |
Lo-Fi Version | Time is now: 8th June 2024 - 05:09 PM |
