| JawjaPorsche |
Jan 16 2012, 04:55 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,463 Joined: 23-July 11 From: Clayton, Georgia Member No.: 13,351 Region Association: South East States |
I see where the Tapered Fuel Hose is no longer available at Pelican Parts:
http://www.pelicanparts.com/cgi-bin/smart/...74%29%2C%20Each Does anyone know an alternative source? Also dumb question. The description says "Tapered Fuel Hose For Connection at Fuel Filter." I thought the hose was also used for the outlet port on the fuel pump because the connection is smaller than the standard hose size: 8 mm? |
| billh1963 |
Jan 16 2012, 05:12 PM
Car Hoarder! ![]() ![]() ![]() ![]() Group: Members Posts: 3,431 Joined: 28-March 11 From: North Carolina Member No.: 12,871 Region Association: South East States |
I thought it was only for the fuel tank line coming out of the tunnel to the input side of the fuel filter.
| wingnut86 |
Jan 16 2012, 05:50 PM
...boola la boo boola boo... ![]() ![]() ![]() Group: Members Posts: 1,054 Joined: 22-April 10 From: South Carolina Member No.: 11,645 Region Association: South East States |
Check Automation and Vertex.
They used to carry them as well. |
| type47 |
Jan 16 2012, 06:12 PM
Viermeister ![]() ![]() ![]() ![]() Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
Chris Foley sells a stainless steel piece that does what this hose does.
| ChrisFoley |
Jan 16 2012, 06:42 PM
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,019 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None
| SLITS |
Jan 16 2012, 06:47 PM
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None |
Gad, go to ACE Hardware or a place like that and get a 3/8" X 1/2" nylon hose barb reducer ... it'll break the piggy bank.
| dangrouche |
Jan 16 2012, 07:46 PM
dangrouche ![]() ![]() ![]() Group: Members Posts: 550 Joined: 1-May 04 From: San Francisco Bay Area Member No.: 2,012 Region Association: None |
I employ Chris' taper stainless adaptor tubing, 90-degree bend, and I never have to worry about this transition rubber hose.
| Cap'n Krusty |
Jan 16 2012, 08:19 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
Gad, go to ACE Hardware or a place like that and get a 3/8" X 1/2" nylon hose barb reducer ... it'll break the piggy bank. ........and when you get that thing home, it'll be the wrong size. You want something close to 9mm x 8mm, not 9mm x 13mm. Have you called the dealer? That's where Pelican and all the others got them. The Cap'n |
| rick 918-S |
Jan 17 2012, 12:03 AM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,239 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
I employ Chris' taper stainless adaptor tubing, 90-degree bend, and I never have to worry about this transition rubber hose. (IMG:style_emoticons/default/agree.gif) I bent mine also! (IMG:style_emoticons/default/unsure.gif) Did the same thing! Funny... (IMG:style_emoticons/default/laugh.gif) |
| SLITS |
Jan 17 2012, 10:23 AM
Gad, go to ACE Hardware or a place like that and get a 3/8" X 1/2" nylon hose barb reducer ... it'll break the piggy bank. ........and when you get that thing home, it'll be the wrong size. You want something close to 9mm x 8mm, not 9mm x 13mm. Have you called the dealer? That's where Pelican and all the others got them. The Cap'n Sorry Cap'n, it depends upon which pump you use ... inlet on CIS pumps is about 1/2" and they do make different size reducers, but not metric that I have found. |
| ClayPerrine |
Jan 17 2012, 10:30 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,542 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
If IIRC, there is a Mercedes Diesel hose that works for this too. But it is weird, as the inlet and outlet are the same size, but the middle is bigger. You just cut it in half to get the reducer hose you need.
| Phoenix914 |
Aug 5 2014, 11:12 AM
Member ![]() ![]() Group: Members Posts: 389 Joined: 6-December 06 From: Oviedo, FL Member No.: 7,322 Region Association: South East States
If IIRC, there is a Mercedes Diesel hose that works for this too. But it is weird, as the inlet and outlet are the same size, but the middle is bigger. You just cut it in half to get the reducer hose you need. Is this the type of hose you're talking about? It looks like a common type of part for MB diesels, but I wonder if there are different sizes? http://www.ecstuning.com/ES1964970/ Has anyone tried this to replace the tapered fuel hose? |
| Dave_Darling |
Aug 5 2014, 01:27 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,335 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
Your hardware store will have hose barbs and fittings in the plumbing department that you can put together that will do the job quite well.
--DD |
| Phoenix914 |
Aug 5 2014, 01:34 PM
Thanks Dave. I'll probably go that route.
The MB part just seemed like a slick way to get 2 tapered hoses! |
| pete000 |
Aug 5 2014, 02:16 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,887 Joined: 23-August 10 From: Bradenton Florida Member No.: 12,094 Region Association: South East States |
Glad I got one a few years back when I started my fuel line replacement project. Car is still in the air and the lines all in boxes in my garage, good grief I need to get my car going again !
I bet AA has them at a new adjusted price ! |
| Phoenix914 |
Aug 5 2014, 02:39 PM
good grief I need to get my car going again ! I bet AA has them at a new adjusted price ! I have the same problem! That's why I'm looking for things like this fuel hose - trying to gather parts for a comprehensive tune up and refresh in hopes of getting on the road again. And even AA has this part listed as "discontinued." |
| ChrisFoley |
Aug 5 2014, 03:14 PM
Trying to find that tapered hose is a waste of time if you're replacing the plastic lines with SS.
| bdstone914 |
Aug 5 2014, 06:58 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,280 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
good grief I need to get my car going again ! I bet AA has them at a new adjusted price ! I have the same problem! That's why I'm looking for things like this fuel hose - trying to gather parts for a comprehensive tune up and refresh in hopes of getting on the road again. And even AA has this part listed as "discontinued." I made one out of a piece of hose that was the correct size for the small end. I clamped a tapered punch in the vise and shoved the hose onto the punch after soaking the hose in boiling water. It stretched the hose enough to work. |
| Phoenix914 |
Aug 5 2014, 07:24 PM
I made one out of a piece of hose that was the correct size for the small end. I clamped a tapered punch in the vise and shoved the hose onto the punch after soaking the hose in boiling water. It stretched the hose enough to work. I was wondering if something like that might work, knowing the original part is unavailable. Sounds like it's worth a try for essentially no cost. |
| mepstein |
Aug 5 2014, 08:06 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,587 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
I bought mine from Chris - Tangerine. He has all the right stuff.
Lo-Fi Version | Time is now: 2nd April 2026 - 08:33 AM |
