> Question: Front Anti-SwayBar Bushings
euro911
post Jan 21 2012, 02:39 PM
I have a 15mm sway bar that I'd like to install on the '75 while we have the fuel tank out (replacing the plastic lines with SS lines).
I've never replaced bushings before, so I'm looking for some expertise from you guys.
The new Pelican bushings appear to be different than the OEM ones we pulled off.
The old bushings had a linear slice that allowed me to remove them. The new bushings are a harder compound and not sliced.
Do I slice them with a hacksaw? or band saw? ... or do I place them in boiling hot water and press them on? (IMG:style_emoticons/default/confused24.gif)
I'm sitting here twiddling my thumbs until I get a good answer ... (IMG:style_emoticons/default/popcorn[1].gif)
Replies(1 - 18)
ChrisFoley
post Jan 21 2012, 03:32 PM
I am Tangerine Racing
I think you have to split them into two pieces.
flash914
post Jan 21 2012, 03:47 PM
I just sliced mine with a box cutter *** CAREFUL*** Put them on a block of wood and cut dowward. Just don't want anyone hurt. (IMG:style_emoticons/default/headbang.gif)
Eric_Shea
post Jan 21 2012, 08:20 PM
PMB Performance
Slice'em
VOX
post Jan 22 2012, 01:00 AM
you guys cut them? really!? i had no idea thats what people did. we actually threw them in hot water, put them on a table vise, squeezed them partially in, once the lip goes in, took them off the vise, smacked the metal side with a hammer/mallet and it popped into place.
Eric_Shea
post Jan 22 2012, 01:04 AM
PMB Performance
Talking about different bushings VOX...
euro911
post Jan 22 2012, 01:20 AM
Yep, these are the bushings that go around the torsion bar at each side, not the drop-link bushings. Still waiting for the drop-link bushings ... hoping to pick those up sometime this coming week.
Just need to get the torsion bar bushings installed so we can reinstall the fuel tank. I can install the drop-links at a future date.
Thanks for the answers ... (IMG:style_emoticons/default/beerchug.gif)
VOX
post Jan 22 2012, 01:27 AM
oh ok, sorry for the mistake. i should take a look at mines and see if they need to be replaced as well.
Dave_Darling
post Jan 22 2012, 03:18 PM
914 Idiot
I did not slice 'em. I pushed the square end of the bar through the bushing. It was a little tough but not absurdly so.
--DD
Eric_Shea
post Jan 22 2012, 07:08 PM
PMB Performance
I honestly don't know how that's possible Dave. Are you sure?
euro911
post Jan 22 2012, 08:08 PM
Yeah (IMG:style_emoticons/default/confused24.gif) ... the old adage "you can't fit a square peg in a round hole" comes to mind (IMG:style_emoticons/default/shades.gif)
Dave_Darling
post Jan 22 2012, 09:19 PM
914 Idiot
I am fairly sure I did. The bushings are somewhat elastic, so they deform. I remember it not being all that easy, though.
--DD
luskesq
post Jan 22 2012, 11:09 PM
The Pelican site says in part in the section on the sway bar bushings: "Note: Front Cup Bushings must be slit on one side to fit around bar."
Keith
euro911
post Jan 22 2012, 11:20 PM
I didn't order them from their on-line catalog, so I didn't read any notes about their installation ... I just called Glenn and let him know what I needed. I should go the their tech article site to see if they have a 'How To' posted (IMG:style_emoticons/default/idea.gif)
I'll probably 'slit' them as recommended. Thanks ...
EDIT
They DO have a tech article: http://www.pelicanparts.com/techarticles/9...ont_swaybar.htm
But get this ... they don't say anything about 'slitting' the bushings - they state they pushed the bar through them (IMG:style_emoticons/default/blink.gif)
"After you have installed the mounts for the sway bar, you then need to install the bar itself. If I remember correctly, it was very difficult to get the bar into the bushings. You basically need to attach the mounts that sandwich the bushing to either side of the car, and then slide the bar through. Leave the nuts pretty loose, as you don't want to compress the bushing while you're sliding the bar through. Luckily, you can put the bar through the bushing on one side before you install it on the car. It's a wise idea to use new bushings for this process, because once the bar is in, it is difficult to take out. This process is a pain because the diameter of the end of the bar is bigger than the bar itself. Once you have the bar through both sets of bushings and mounted to the car, then tighten the mounts."
jesiv
post May 14 2013, 07:03 PM
They are split from the factory
Regards
James
jesiv
post May 14 2013, 07:06 PM
These are available from Porsche now for $15
Regards
James
Scott S
post May 15 2013, 01:02 PM
Small Member
Is this the same process for aftermarket (Weltmeister) sway bar bushings?
euro911
post Aug 5 2013, 10:56 PM
If they look like they're gonna be tough getting past the ends, maybe so (IMG:style_emoticons/default/confused24.gif)
I'm waiting on the new and improved adjustable arms from dfelz (and the winter season) to install everything (IMG:style_emoticons/default/popcorn[1].gif)
scott_in_nh
post Aug 6 2013, 06:35 AM
QUOTE(Dave_Darling @ Jan 22 2012, 11:19 PM) *
--DD
I didn't slice mine either and didn't find it all that hard (nor all that easy) to get over the square end.
YMMV
- Lo-Fi Version Time is now: 17th June 2026 - 05:26 AM
