Generator light |
Generator light |
elwood-914 |
Aug 27 2004, 09:13 PM
elwood-914 Group: Members Posts: 387 Joined: 29-December 02 From: Plymouth CA Member No.: 38 |
Help! The generator light came on. Everytime I activate the turn signal or brake or put on the em brake the radio stops and the tac jumps and I have no brake lights. I have replaced the voltage regulator and no change and the voltage at the battery seems just fine. Tonight I have no tac and no brakes or turn sygnals. Bad ground?? The car starts up fine and other than the problems described
the car runs fine. Bad grounds |
GaroldShaffer |
Aug 27 2004, 09:28 PM
You bought another 914? Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
BTDT, Bad grounds. Check the tranny ground strap. 1st make sure there is one and disconnect it and clean clean clean the connection points.
Cap'n Krusty |
Aug 28 2004, 10:29 AM
Check the fuses. Most common cause of the problem. The Cap'n
Brad Roberts |
Aug 28 2004, 05:19 PM
Yep. You probably knocked out a fuse on the fuse panel with your feet (if you have no cover)... I *think* it is no. 7 that causes this.
B |
Lo-Fi Version | Time is now: 11th June 2024 - 02:43 AM |
