> valve adjustment, hope i didnt bent a valve
opera guy
post Aug 29 2004, 03:02 PM
following the article on PP's site, i began to adjust my valves yesterday.
after i found TDC and begin to work on cylinder #1. i took out nut on the intake, and removed the valve adjustment screw to inspect for pitting. the screw looked fine so i put it back in. somehow, the screw wont go back to its prior location. i was only able to screw it in about 6-8 turns. I am positive im not cross-threading it. i think the valve popped out (closed inside the combustion chamber). how do i push the valve INTO the combustion chamber so i can continue threading the valve adjustment screw in and continue to do my adjustment?
please tell me i didnt bent a valve, please!!
Replies(1 - 9)
Aaron Cox
post Aug 29 2004, 03:04 PM
Professional Tinkerer
shouldnt be any load on the rocker when your working on it
ie. Valve directly across the engine should be open
SpecialK
post Aug 29 2004, 03:08 PM
aircraft surgeon
kinda sounds like your push-rod isn't seated down in the lifter/tappet. Wiggle the push-rod around see if that gets you the clearance needed.
nebreitling
post Aug 29 2004, 03:28 PM
Member Emeritus
are you SURE that you were at TDC?
opera guy
post Aug 29 2004, 04:20 PM
QUOTE(nebreitling @ Aug 29 2004, 01:28 PM)
yeah, i tripple checked.... and checked again.
opera guy
post Aug 29 2004, 04:21 PM
QUOTE(Special_K @ Aug 29 2004, 01:08 PM)
this seems to be it. i messed around with the rocker arm and fixed one of them (cylinder 4 exhaust). now only one left (cylinder 1 intake) to "mess" "wiggle" wish me luck
opera guy
post Aug 29 2004, 05:00 PM
YES!!!!!!!
Special_K you freaking RULE!! (IMG:style_emoticons/default/smilie_pokal.gif) lemme know when you're coming to socal, i owe you a beer.
i also like to thank the Academy for acox914's help!!! (IMG:style_emoticons/default/smilie_pokal.gif) you're not old enough to drink, i owe you a Pepsi (IMG:style_emoticons/default/tongue.gif)
car sounds 100X better already. i think i'll let it sit over night and double check the adjustments again.
this board ROCKS!!!!
Aaron Cox
post Aug 29 2004, 05:18 PM
john,
you know the number now:
9-1-4 whats youre emergency? (IMG:style_emoticons/default/lol2.gif)
glad you got it to work out,
SpecialK
post Aug 29 2004, 06:26 PM
aircraft surgeon
(IMG:style_emoticons/default/mueba.gif)
Glad I could help! (IMG:style_emoticons/default/beer.gif)
redshift
post Aug 29 2004, 10:04 PM
Bless the Hell out of you!
lol Aaron.
M
- Lo-Fi Version Time is now: 15th March 2026 - 05:37 PM
