Problems mounting tires, 205 Azines on Fuchs |
qa1142 |
Aug 29 2004, 08:04 PM
Whiplash Group: Members Posts: 1,514 Joined: 1-June 04 From: Lake Zurich, Illinois Member No.: 2,140 |
Any one have problems getting thier tiers mounted?
I bought a set of Falken Azines from Discount Tire. 3 went on find, they could not get bead to set on 4th rim. They put it in this cage thing and inflated to 120 psi before bead set. After that, they could not get it balanced. So I missed Tire Rack auto cross today (IMG:style_emoticons/default/finger.gif) . Tire is not longer round, they are getting me another one Tuesday... which is OK but Has anyone else had issues getting tires mounted? How about problems with Azines? Hope this is a one off and not a trend with these new tires. |
Brad Roberts |
Aug 29 2004, 08:08 PM
I have personally mounted 12 of these tires on Fuchs rims... no problems. Much easier than mounting a Hoosier or Kuhmo on a Fuchs alloy. If one side (bead) doesnt seat tell them to use the machine that they use to UN-seat the tires. They can use it to straighten out the bead on the OPPOSITE side of where the issue is. Hard to explain without showing you a pic of the tire machine.
B |
GaroldShaffer |
Aug 29 2004, 08:11 PM
You bought another 914? Group: Benefactors Posts: 7,623 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
I wonder where you were. Mine are not mounted on my Fuchs but the local tire shop did this to one of my steel rims when mounting them.
They had no probelm with the other rims and paid for a new (used) rim No damage to the tires. Attached image(s) |
qa1142 |
Aug 29 2004, 08:15 PM
Thanks Brad
I think I know what your are saying. I'll have to watch more closely as they mount the new one Tuesday. |
Brad Roberts |
Aug 29 2004, 08:18 PM
Do you know what lube they are using ?? Too much lube inside the tire and it will never balance.
B |
GaroldShaffer |
Aug 29 2004, 08:48 PM
K-Y (IMG:style_emoticons/default/ohmy.gif) (IMG:style_emoticons/default/cool_shades.gif) sorry I couldn't resist (IMG:style_emoticons/default/biggrin.gif)
Lo-Fi Version | Time is now: 2nd June 2024 - 03:52 PM |
