| echocanyons |
Aug 29 2004, 10:28 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,112 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California
There is a bit of wiggle room when you bolt the struts to the chassis, is there a certain way to get it close enough to be able to drive it to an alignment shop?
Also I cant find any torque values for the the three bolts on the strut top, the larger top strut bolt or the ball joint pin nut does anyone have these handy? |
| Brad Roberts |
Aug 29 2004, 10:45 PM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Um... why did you unbolt those bolts ??
B |
| Aaron Cox |
Aug 29 2004, 10:46 PM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
QUOTE(Brad Roberts @ Aug 29 2004, 09:45 PM) Um... why did you unbolt those bolts ?? B there goes your alignment...out the window... |
| echocanyons |
Aug 29 2004, 10:52 PM
I swapped struts so I could run new brakes and 5x130mm wheels
I had to remove the top bolt to use the stock strut mount because the welds on the underside nuts from the donor had broken loose. I changed from stock to 911 type |
| echocanyons |
Aug 29 2004, 10:55 PM
pic
| redshift |
Bless the Hell out of you! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,926 Joined: 29-June 03 Member No.: 869 |
Looks like a good enough reason.
M |
| Aaron Cox |
Aug 29 2004, 10:56 PM
QUOTE(echocanyons @ Aug 29 2004, 09:52 PM) I swapped struts so I could run new brakes and 5x130mm wheels I had to remove the top bolt to use the stock strut mount because the welds on the underside nuts from the donor had broken loose. I changed from stock to 911 type (IMG:style_emoticons/default/wacko.gif) ..a little confoozed. u should have only had to unbolt the 22mm but at the top of the fenderwell to change out struts. 1 nut at the top surounded by the 3 allen head screws.... (IMG:style_emoticons/default/unsure.gif) |
| echocanyons |
Aug 29 2004, 10:59 PM
I removed the whole strut mount to use the newer ones from the donor but when I got to the point of installing them I realized the ones I had planned to use were unusable. At that point I swapped the tops for the stock ones.
| Brad Roberts |
Aug 29 2004, 11:05 PM
Scary. I hope the struts are not bent...
Just stick them in the middle of the 3 holes. It will get you where you need to go (alignment shop) B |
| echocanyons |
Aug 29 2004, 11:13 PM
Thanks
QUOTE Scary. I hope the struts are not bent... Me too. Has anyone encountered the bolts on the underside breaking free? It looks like they were just spot welded to the tops. |
| echocanyons |
Aug 29 2004, 11:22 PM
heres a pic
| Brad Roberts |
Aug 29 2004, 11:25 PM
This normally means the strut took a serious hit.
B |
Lo-Fi Version | Time is now: 8th December 2025 - 03:18 PM |
