> 2056 Build
yeahmag
post Feb 2 2012, 12:49 AM
Installed crank, gears, cam, and rods. Dry fit CB's dry sump pump and modified the tang and clearanced drive tang boss.
5 Pages V  1 2 3 > »
Replies(1 - 19)
EdwardBlume
post Feb 2 2012, 01:01 AM
QUOTE(yeahmag @ Feb 1 2012, 10:49 PM) *
(IMG:style_emoticons/default/beer.gif)
ThePaintedMan
post Feb 2 2012, 06:43 AM
Cool! Wish I had the guts to attempt a rebuild. One day!
jaxdream
post Feb 2 2012, 09:06 AM
Will the fan housing bolt up / clear the new pump ?? Or are using another cooling option ?? Looks good !!! (IMG:style_emoticons/default/piratenanner.gif)
Jack
mrbubblehead
post Feb 2 2012, 09:52 AM
Twodollardoug
what are you going to do about your engine mounts?
yeahmag
post Feb 2 2012, 10:46 AM
I will need to modify the fan housing to clear the oil pump. I will also have to custom make some motor mounts.
mrbubblehead
post Feb 2 2012, 03:55 PM
Twodollardoug
you are one step ahead of me. i am doing the same as you. same pump also.....
i just finished all my case mods, and concentrating on building my sump tank.
did you hav to grind your cam bolts? do you remember how much you took off the snout of the pump?
i am going to use tangerine racing's horizontal fan set up, so my engine mounts shouldnt be a problem.
yeahmag
post Feb 2 2012, 04:01 PM
I ground about 2mm off that pump. Maybe more. I also made the tang have some angle at the end like the stock tangs. I made the tang length match the one I got from Raby years ago. I took a bit off the boss holding the drive tang to make sure it was clear of the cam. I probably took off 1mm at most on the boss.
I did grind my cam bolts to be safe, but I probably didn't have to with the ones Jake sent me.
What case mods did you do?
mrbubblehead
post Feb 2 2012, 04:16 PM
Twodollardoug
since im not using the stock oil cooler or stock oil filter i took them out of the circuit. i also welded up the relief holes and took both relief system out of the circuit also. (IMG:http://www.914world.com/bbs2/uploads_offsite/i722.photobucket.com-12492-1328220964.1.jpg)
yeahmag
post Feb 2 2012, 04:19 PM
How are you routing the oil for the pressure stage? The galley from the pressure side of the pump goes right to the oil filter...
mrbubblehead
post Feb 2 2012, 06:18 PM
Twodollardoug
i used this diagram (IMG:http://www.914world.com/bbs2/uploads_offsite/i722.photobucket.com-12492-1328228312.1.gif)
and modified it to this (IMG:http://www.914world.com/bbs2/uploads_offsite/i722.photobucket.com-12492-1328228669.1.gif)
1. jaycee 3 port remote oil filter/relief @ 80 psi
2. remote oil cooler
3. sump tank
in my picture you can see i welded a fitting on the passage from the pump (where the old filter stand was)
then it goes thru the remote filter, oil cooler, and then straight to the mains via the oil cooler location. another welded fitting. i just cut of the the old cooler stand off the case.
yeahmag
post Feb 2 2012, 09:41 PM
Here are pictures of the pistons after going through the ultrasonic cleaner and then me balancing them. I used a 1g scale, a 1/2" drill bit, and an air powered angle grinder with a small sanding disk (just to clean up any sharp edges). The all are at 570g now. They were as much a 3g out. Weights ranged from 570g to 573g.
Valy
post Feb 2 2012, 11:20 PM
QUOTE(mrbubblehead @ Feb 2 2012, 04:18 PM) *
3. sump tank
So how do you pump oil out of the sump?
jmill
post Feb 3 2012, 07:07 PM
Green Hornet
I was thinking the same thing. Somehow youi need to get the oil in the tank to the suction side of the pump. All the dry sump systems I've seen have a scavenge and a pressure pump.
mrbubblehead
post Feb 3 2012, 07:22 PM
Twodollardoug
QUOTE(jmill @ Feb 3 2012, 05:07 PM) *
i know, this diagram was just for me. i didnt draw them in because i know that the feed and return from the sump tank go to the oil pump. this diagram was to figure out how i was gonna get in and out of the case.
Woody
post Feb 3 2012, 07:48 PM
Sandbox Rabblerouser and head toilet scrubber
You are going to love that engine. (IMG:style_emoticons/default/piratenanner.gif) (IMG:style_emoticons/default/beerchug.gif)
mrbubblehead
post Feb 4 2012, 04:18 PM
Twodollardoug
any more progress yeahman? do you know what you are going to use for a sump tank yet?
yeahmag
post Feb 14 2012, 11:32 AM
Been cleaning parts like mad. Finally ready to close the case up after checking the fit of the drive tang and boss on the CB dry sump pump.
I also got around to modifying the oil filter housing. I used a slide hammer with a small, blind bearing pull attachment and removed the bypass system. I then cut an AL slug to fit and MIG'ed it in.
With regards to the tank, I'm using a very nice Patterson tank that Blake sold me. I'll be mounting it up front and trying to figure out how to mount an oil cooler up there too.
yeahmag
post May 24 2012, 12:22 PM
OK. The long block is together and I'm starting on the valve train geometry. Here are some pic's:
The head after using Ajax to lap the cylinders
yeahmag
post May 24 2012, 12:23 PM
After the copper spray to help with the carbon seal.
5 Pages V  1 2 3 > »
- Lo-Fi Version Time is now: 23rd October 2025 - 08:17 PM
