frnt bearing endplay, before i button things up |
rhodyguy |
May 2 2003, 08:34 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,097 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
new bearings, races,seals. when installing the rotors i ran the clamping nut down to the point where the rotor would'nt turn w/out firm pressure. eased off, just get movement on the washer when i insert a screwdriver. rotor spins nicely. is the general consensus good to go? one step closer.
kevin |
Dave_Darling |
May 2 2003, 11:30 PM
If the washer moves when you pry it with a screwdriver, it's loose enough.
Button it up, put the road-wheel on. Grab the wheel at 12 and 6 o'clock, wiggle wiggle wiggle. A small "click" is great, a large "clunk" is too much play. No "click" at all may very well be too tight, which is also bad. 914 and 911 front wheel bearings will loosen up if you load them up enough. Autocrossing will make them looser and looser, and after a while they need to be tightened. I've done the wheel bearing adjustment in 20 minutes on the "false grid" at Candlestick. To a competitor's car. (The bastard had the nerve to out-drive me after I got his car to pass tech!!! Imagine, being more skilled than me after that!! (IMG:style_emoticons/default/wink.gif) ) --DD |
Lo-Fi Version | Time is now: 12th June 2024 - 11:51 PM |
