real time koni ?, like NOW!! |
rhodyguy |
Sep 3 2004, 07:44 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,085 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
on the yellow rears the threaded collar has a machined inset area on one end and the other one is just flat. does the clip on the strut go inside the machined area? al blose is over doing an install.
kevin Attached image(s) |
Brad Roberts |
Sep 3 2004, 07:46 PM
Move the clip to its lowest setting and flip the machined part so it sits as far down on the clip as it can. This will help squeeze the clip into the groove.
B |
Brad Roberts |
Sep 3 2004, 07:48 PM
When you get everything on the car.. twist the RED machined piece to raise or lower the gold perch. It is easier to turn the red piece than it is to turn the gold piece.
I thought there was a Word .doc going out with each kit.... B |
rhodyguy |
Sep 3 2004, 07:57 PM
thank you. no intructions. stick around a while (IMG:style_emoticons/default/wink.gif)
Jeroen |
Sep 3 2004, 09:06 PM
914 Guru Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe |
Brad,
You told me the "hats" that come with the coil-over kit still needed to be machined I wrote the dimensions down somewhere but obviously can't find 'm anymore (IMG:style_emoticons/default/headbang.gif) How wide and deep do they need to be drilled out? cheers, Jeroen |
Brad Roberts |
Sep 4 2004, 01:05 AM
Did you buy from me ??
Only the very first few sets needed any work to them. Flip one over and shoot a pic for me. I'll let you know if it needs it or not. B |
Jeroen |
Sep 4 2004, 05:27 AM
Yep, I bought it from you (while I was there)
You told me how much it needed to be drilled, but I lost my notes... |
rhodyguy |
Sep 4 2004, 07:25 AM
i would bet that the old struts were the ones that came with the car. the fronts went in and out sort of like an accordian. the remnants of one rubber stops that was left had a 914 part #on it. i hope al comes on this a.m. and shares his impressions on the handling improvements. i have to take the rears on my car apart. <_<
kevin |
ablose58 |
Sep 4 2004, 08:22 AM
rust never sleeps Group: Members Posts: 584 Joined: 6-December 03 From: port orchard,wa. Member No.: 1,422 |
OMG, Did that make a world of difference (IMG:style_emoticons/default/smilie_pokal.gif) I could swear that I am driving a totally different car (IMG:style_emoticons/default/beer.gif) Rides and handles like a dream and it doesn't feel like I am driving a buckboard anymore (IMG:style_emoticons/default/boldblue.gif) Kevin thanks for all your help (IMG:style_emoticons/default/clap56.gif) This site rocks. (IMG:style_emoticons/default/cool_shades.gif) AL
Brad Roberts |
Sep 4 2004, 11:23 AM
Glad we could help Al. NOW. Set them full firm and run around town... then set the front full soft but leave the rear full firm. Then set the rear soft and leave the front soft... run around town. I want you to know the difference. You have to experience the difference to fully understand how much adjustment you have.
B |
ablose58 |
Sep 4 2004, 11:15 PM
Thanks, Brad, I will do that on my way home from work tonight (IMG:style_emoticons/default/smilie_pokal.gif) AL
Lo-Fi Version | Time is now: 3rd June 2024 - 02:06 AM |
