Keep blowing my hazard fuse |
ChrisReale |
May 2 2003, 10:53 PM
Sleazy Group: Members Posts: 2,665 Joined: 20-January 03 From: San Francisco Member No.: 176 |
WTF?? It takes an 8 amp fuse. I went through three 8 amps, eack would spark and blow before I put in a 16 amp. It works now. Why was it blowing fuses. I want to make sure everything is ok, not just patch it over...idea's?
Dave_Darling |
May 2 2003, 11:07 PM
Which fuse number? 11?
--DD |
ChrisReale |
May 2 2003, 11:11 PM
yes, number 11 second from the right (IMG:style_emoticons/default/pain30.gif)
jonwatts |
May 2 2003, 11:14 PM
no rules, just wrong Group: Benefactors Posts: 2,321 Joined: 13-January 03 From: San Jose, CA Member No.: 141 |
Please post your fix for this problem. The hazzard circuit in a 914 probably gets more use than the headlights (IMG:style_emoticons/default/lol2.gif)
Dave_Darling |
May 2 2003, 11:56 PM
Crap... Why couldn't it be a 74+ car, with the current flow diagram that is easy to understand??
OK, OK... Stuff that fuse #11 feeds: Buzzer. (I assume this is under the passenger's seat.) Emergency flasher switch. Interior light. That's it. So make sure that your interior light isn't unplugged, and make sure that the buzzer (whether undre the seat or up on top of the fuse panel, or wherever) isn't shorting out. Then unplug the black/red wire from the hazard switch and see if that helps. --DD |
Dave Cawdrey |
May 3 2003, 12:45 AM
Dumbo going poop, Daddy :) Group: Members Posts: 818 Joined: 22-January 03 From: Seattle, WA USA Member No.: 182 |
Didn't you get a new interior light recently?
Drums66 |
May 3 2003, 10:02 AM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
Sometimes it comes back to what you F....d with last! (IMG:style_emoticons/default/confused24.gif)
Curvie Roadlover |
May 3 2003, 04:22 PM
Two trunks are better than one! Group: Members Posts: 2,025 Joined: 29-December 02 From: Southeast Michigan Member No.: 42 |
QUOTE(Drums66 @ May 3 2003, 08:02 AM) Sometimes it comes back to what you F....d with last! (IMG:style_emoticons/default/confused24.gif) So true. Always look at what you last messed with. |
ChrisReale |
May 3 2003, 05:29 PM
Well, since my interior light is MIA, that could be it (IMG:style_emoticons/default/mellow.gif)
Dave_Darling |
May 3 2003, 06:13 PM
Power for the light is always "hot". If the power wire is down behind the backpad and touching the floor pan (common when the light it MIA), it'll blow the fuse every time. Find the wire and tape up the end.
--DD |
Lo-Fi Version | Time is now: 16th June 2024 - 11:24 PM |
