Success ?, Problem solved - no more overcharge |
plas76targa |
Sep 4 2004, 12:47 PM
Senior Member Group: Members Posts: 885 Joined: 22-February 04 From: Frederick, MD Member No.: 1,700 Region Association: MidAtlantic Region |
(IMG:style_emoticons/default/smilie_pokal.gif) I think I've solved it. I posted earlier my frustration with the Alternator overcharging even with a NEW Voltage Regulator. Thanks to searching previous posts and your responses I checked the varous grounding points, added a ground strap at trans (there was one already but one more wouldn't hurt), moved the Battery ground to the fan shroud. I removed the alternator and had it tested - it's fine. Then based on a year old post, I thought to test the relay board. A local 914 club member has loaned me an extra board he had, and that solved it. The voltage at battery is 13.6 now. Cross your fingers.
I highly recommend reading the Alternator replacement and problem analysis segments on the bird board. As another thread on this board states, "this place ROCKS! (IMG:style_emoticons/default/agree.gif) So I post this for anyone who may be roasting their battery, have 14 - 18 volt reading at the battery terminals, the gen light on dash responding normally, and be puzzled as to what to check next. Search the posts, clean all your grounding points, read the bird board and try a relay board if you can get your hands on one. time for a beer! (IMG:style_emoticons/default/beer3.gif) |
SpecialK |
Sep 4 2004, 01:05 PM
aircraft surgeon Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 |
Ahhh...Once again a successful fix brought to you the the nice folks on the 914 Club BBS (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/beer.gif)
Happy/safe Labor Day Weekend everyone!! |
JoeSharpOld |
Sep 4 2004, 03:33 PM
Does it seem cold to you Group: Members Posts: 361 Joined: 29-April 04 From: Camping in Neverland Member No.: 2,001 |
Kool Matt: Thats good to hear (read). (IMG:style_emoticons/default/wink.gif) But I wish You could have figured out to send me the extra volts, I still could use them. (IMG:style_emoticons/default/biggrin.gif)
Joe |
ppickerell |
Sep 4 2004, 03:39 PM
914 addicted Group: Members Posts: 1,679 Joined: 14-October 03 From: Pleasanton, CA. Member No.: 1,246 |
Glad to hear that worked.
plas76targa |
Sep 4 2004, 09:42 PM
(IMG:style_emoticons/default/clap56.gif) Thanks go to you Pat for loaning me the board. I'm working on getting a replacement of my own shortly.
Joe, If I could have sent the unused volts, I would have!! (IMG:style_emoticons/default/wink.gif) |
JoeSharpOld |
Sep 5 2004, 04:14 AM
Matt: I have an extra board, are you coming to Ventura?
Joe |
Lo-Fi Version | Time is now: 7th June 2024 - 01:13 AM |
