rear 5 lug conv. question.., what do i need besides 911 hub? |
opera guy |
Sep 6 2004, 02:31 PM
Member Group: Members Posts: 337 Joined: 28-June 04 From: upland, ca Member No.: 2,268 |
im going to do the 5 lug conversion on my 2.0.. gonna drill the rotor in the front bc it seems that works out ok.
my question is regarding the rear. i am in the middle of negotiation about a set of 911 rear hubs. naturally, they are 5 lugs already. do i just take the 914 hub out and slap on these 911 hubs? ( i have a set of rear bearings already bee in the freezer for a few weeks). or do i need ot get the stub axle changed too? see pic Attached image(s) |
SirAndy |
Sep 6 2004, 02:40 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
you'll need 914/6 stub axles to fit a 911 hub. they're expensive.
or you can redrill your /4 hubs for 5-lug ... (IMG:style_emoticons/default/wink.gif) Andy |
Mueller |
Sep 6 2004, 02:43 PM
or you can use early 911 axles...do a search here, someone just a few months ago listed all the parts and years needed....a spacer is needed as well which is available from a member on here.
BIGKAT_83 |
Sep 6 2004, 03:40 PM
Senior Member Group: Members Posts: 1,798 Joined: 25-January 03 From: Way down south Bogart,GA Member No.: 194 Region Association: South East States |
Use a spacer like this to use the 911 axles on the 901 trans axle.
I used these with 89 c4 axles and 911 hubs and vented rotors. I made a extra set when I made mine. Attached image(s) |
Steve |
Sep 6 2004, 10:30 PM
914 Guru Group: Members Posts: 5,606 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I dug this up from previous threads.
Early 911 stub axles 4-bolt CV 901-332-232-00 Early '69 to '74 Axles CV assemblies 911-332-033-08 Sportomatic drive flange for tranny output. Course spline. This has a slightly deeper dish than the regular 901 output flanges and allows you to bolt the entire assembly up without having to use a spacer. (70-73) 901-332-209-15 Here is what to look for... 4 bolt ( if your CVs are 4-bolt). Course splined, tranny out put flange, from 901 or early 915 transmission. The large end of the flange that bolts to the axle is cupped. The desired sporto output flange has a deeper dish (about 1/4 to 3/8") or so. It is obvious when comparing the two. This is the desired one. It's this extra depth that allows you to use this combo without a spacer. Or you can you can run standard trans hubs with the regular 901/915 course spline. The .250 difference is split between two CV's which ends up being .125 on either end.The CV's have enough play that you can do this NO problem. We beat the piss out of them in race cars and V8 conversion cars with NO failures. The early 911 (69-71) hubs use the same wheel bearing as the 914-6 (and 914-4). Some people recommend the sporto trans hubs but others said the extra spacing is not needed and you can use standard 901 trans hubs. The adapters also look way cool and look to be a lot less hassle. I have heard that the renegade adapters leak unless you use permatex with the gasket. The renegade adapters use bus cv and axles. Steve |
Lo-Fi Version | Time is now: 31st May 2024 - 05:56 PM |
