Rear tires rubbing |
jmargush |
Sep 7 2004, 06:41 AM
Member Group: Members Posts: 460 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
I am running 195/60 on the street and 205/50 autoxing. My street tires are very close to the inner fender well(trunk side/ inside of tire) and might even rub on hard coenering. the track tires definatley rub. This is more eveident on the passenger side than the driver side.
The only way I see to fix this is to take negative camber out or use spacers. Any other ideas? What aligment settings are you using? If I remember I set the rear at .5 to 1 degrees less than the front. front being -1.5 to -2 if I remember correctly |
SirAndy |
Sep 7 2004, 09:45 AM
Resident German Group: Admin Posts: 41,675 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Rockaria |
Sep 7 2004, 10:01 AM
ZippidyDoDah... Group: Members Posts: 817 Joined: 2-May 03 From: Southwest, USA Member No.: 645 Region Association: None |
Sounds like it's time to get out the ol' wooden baseball bad and slightly roll the fenders...
http://www.914world.com/bbs2/index.php?act...&hl=fender+roll |
anthony |
Sep 7 2004, 10:03 AM
2270 club Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 |
If it's a nice car with nice paint I would touch it with a bat. I'd have a body shop do it with the proper tool.
Part Pricer |
Sep 7 2004, 10:32 AM
Believe everything I post Group: Benefactors Posts: 1,825 Joined: 28-December 02 From: Danbury, CT Member No.: 35 |
Guys, please re-read his post. His problem is with the inside of the tires. Rolling the fender won't address that problem.
You're on the right track. Camber or spacers might help. But, to re-ask Andy's question, what wheels are you running? Once we get a more complete picture, then we can give you the wrong advice. (IMG:style_emoticons/default/biggrin.gif) |
Rockaria |
Sep 7 2004, 10:42 AM
QUOTE(jmargush @ Sep 7 2004, 06:41 AM) ... My street tires are very close to the inner fender well(trunk side/ inside of tire) ... Dohhh.... [Homer simpson Icon goes here] |
jmargush |
Sep 7 2004, 10:57 AM
I am running fuchs on the street 195/60 cheap junk tires that came with the wheels
Mahles on the track 205/50 Kumho victorracer |
Aaron Cox |
Sep 7 2004, 11:15 AM
im guessing too much negative camber? tall tires could rub with too much neg camber
Lo-Fi Version | Time is now: 7th June 2024 - 07:37 AM |
