Sooooooooo Close........ |
Scott S |
Feb 23 2012, 12:38 PM
Small Member Group: Members Posts: 1,697 Joined: 30-April 03 From: Colorado Member No.: 633 |
I am so close! Last night I got the clutch/tranny/starter all done up , installed the engine tins, plugs, wires, pertronix and MSD coil (pulled of that really "cool" decal). Have one small issue with the throttle linkage (need to contact Rich J) and then in the car it goes!
North Hollywood just called this morning and my tach is done too. I just have one concern - the factory oil line that attaches to the bottom tank has a 90 degree fitting on one end, and a slightly less than 90 degree fitting on the other. Does anyone know what end attaches to the tank? I attached the less than 90 fitting to the tank and I am now concerned it is backwards - which means pulling out the damn tank....... sorry for the camera phone quality... Attached thumbnail(s) |
wndsnd |
Feb 23 2012, 12:44 PM
You wanted a horse, but got a goat. Nobody wants a goat.... Group: Members Posts: 2,861 Joined: 12-February 12 From: North Shore, MA Member No.: 14,124 Region Association: North East States |
I am so close! Last night I got the clutch/tranny/starter all done up , installed the engine tins, plugs, wires, pertronix and coil. Have one small issue with the throttle linkage (need to contact Rich J) and then in the car it goes! North Hollywood just called this morning and my tach is done too. I just have one concern - the factory oil line that attaches to the bottom tank has a 90 degree fitting on one end, and a slightly less than 90 degree fitting on the other. Does anyone know what end attaches to the tank? I attached the less than 90 fitting to the tank and I am now concerned it is backwards - which means pulling out the damn tank....... sorry for the camera phone quality... Soooooooo Envious........ That engine looks awesome. Your car is going to be fantastic.... |
AZ914 |
Feb 23 2012, 01:55 PM
914 Dumbass Group: Members Posts: 1,459 Joined: 6-January 03 From: Sunny Tucson Member No.: 98 Region Association: Southwest Region |
The pics are of the engine and oil cooler, you mean the fitting on the bottom of the oil tank in your fender? The line that attaches to the one in your last picture? I don't have stock lines, but I'd guess the less than 90 deg goes to the tank since there is less clearance in the fender. I also assume it depends on which tank you have.
jcambo7 |
Feb 23 2012, 02:10 PM
Senior Member Group: Members Posts: 1,664 Joined: 24-December 08 From: Graham, WA Member No.: 9,867 Region Association: Pacific Northwest |
I see that Andy took your pictures. Looking good!
RiqueMar |
Feb 23 2012, 02:12 PM
Enrique Allen Mar Group: Members Posts: 2,169 Joined: 28-August 08 From: San Diego, CA Member No.: 9,478 Region Association: Southern California |
So f'in cool! (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif) (IMG:style_emoticons/default/smilie_pokal.gif)
rgalla9146 |
Feb 23 2012, 02:21 PM
Advanced Member Group: Members Posts: 4,569 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None |
I see that Andy took your pictures. Looking good! Stock tank ? the less /more than 90 fitting attaches to the tank. Stock length hose to nipple under engine oil cooler ? With that longer-than-stock nipple on the cooler you are going to have a pretty tight turn towards the tank bottom line. |
Eric_Shea |
Feb 23 2012, 02:40 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Go Scott Go!
Scott S |
Feb 23 2012, 02:43 PM
That is my concern. both lines are stock replacements from Rich Johnson. He also did the mod on the oil cooler. Being that he has done a million of these, I am very confident in his expertise. If it does not work, I guess I could send line that attaches to the cooler to Jonathan at GPR and have him swap the straight fitting for a 90 where it meets the tank side line. Glad I didn't weld the -6 oil line hook to the car yet.
Scott S |
Feb 23 2012, 05:12 PM
I have two of these factory oil line fittings. If the second line is to long, can I cut off the crimped fitting and use one of these on the new line instead?
Attached image(s) |
02loftsmoor |
Feb 23 2012, 07:06 PM
Senior Member Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region |
man that looks great (IMG:style_emoticons/default/w00t.gif)
Socalandy |
Feb 23 2012, 07:18 PM
Its got to be Yellow!!! Group: Members Posts: 2,432 Joined: 29-August 09 From: Orange Member No.: 10,742 Region Association: Southern California |
Looks awsome!!!
Gint |
Feb 23 2012, 09:08 PM
Mike Ginter Group: Admin Posts: 16,083 Joined: 26-December 02 From: Denver CO. Member No.: 20 Region Association: Rocky Mountains |
That looks so cool Scotty.
Lo-Fi Version | Time is now: 10th June 2024 - 01:48 PM |
