Question for 6 owners, Bolt sitting between head and chain tensioner housing?? |
Jeffs9146 |
Feb 24 2012, 09:35 PM
Ski Bum Group: Members Posts: 4,062 Joined: 10-January 03 From: Discovery Bay, Ca Member No.: 128 |
I was changing my oil and I notice a leak coming from between the valve cover and the back of the chain tensioner housing!
There are no leaks on the top of the motor and no leaks from the oil return tubes but there is a gap between the back of the housing and the head that has a bolt in it. I have read that there can be a leak from the rocker arm pivot shaft that is in the general area. So the question is could the rocker shaft bolt have fallen out and be the bolt that is between the valve cover and the tensioner housing? Here is a photo of the bolt and where the leak seems to be! Attached thumbnail(s) |
ClayPerrine |
Feb 24 2012, 09:40 PM
Life's been good to me so far..... Group: Admin Posts: 15,515 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
Remove the lower valve cover and take the bolt out. That area is not in the oil system. Once it is out, you should be able to see where it came from.
Jeffs9146 |
Feb 24 2012, 09:50 PM
Thanks I am waiting to get the valve cover gaskets before removing the cover!
I read in the book 101 Projects for your Porsche 911 that the rocker arm seal can fail in that area and is "a 911 mechanics best-kept secret"! And, that is in the general location of the #4 cylinder, looks like exhaust, rocker arm!? I was hoping someone had some kind of idea where the leak might be coming from as well as what kind of bolt can "just appear" in that location!? |
ClayPerrine |
Feb 24 2012, 10:02 PM
It is entirely possible it is the bolt out of the center of the rocker arm. But I can't tell from the picture. Best way is to take the valve cover off and take a look.
Make sure you drain the oil first. When the engine is off, the tank will drain back to the sump, and it fills up the lower end of the valve covers too. |
tomeric914 |
Feb 24 2012, 10:14 PM
One Lap of America in a 914! Group: Members Posts: 1,259 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States |
It's more likely that the O ring between the chain box and cylinder head is beginning to leak. I replaced both of mine with the engine in the car. Not easy, but mine doesn't leak a drop from that area now. Took about 8 hours total to do both sides.
Jeffs9146 |
Feb 24 2012, 10:25 PM
It's more likely that the O ring between the chain box and cylinder head is beginning to leak. I replaced both of mine with the engine in the car. Not easy, but mine doesn't leak a drop from that area now. Took about 8 hours total to do both sides. Wow you did that with the motor in!!?? Don't you have to take off the timing chain and cam gear to get the chain box off?? I don't even want to think about it!@!$$#$#%$@* (IMG:style_emoticons/default/headbang.gif) |
6freak |
Feb 25 2012, 12:17 AM
MR.C Group: Members Posts: 4,740 Joined: 19-March 08 From: Tacoma WA Member No.: 8,829 Region Association: Pacific Northwest |
tomeric914 |
Feb 25 2012, 07:28 PM
Wow you did that with the motor in!!?? Don't you have to take off the timing chain and cam gear to get the chain box off?? Yep. Here's a lnk to the abridged version: http://www.914world.com/bbs2/index.php?s=&...t&p=1500608 |
Jeffs9146 |
Feb 26 2012, 12:50 AM
Wow you did that with the motor in!!?? Don't you have to take off the timing chain and cam gear to get the chain box off?? Yep. Here's a lnk to the abridged version: http://www.914world.com/bbs2/index.php?s=&...t&p=1500608 (IMG:style_emoticons/default/pray.gif) (IMG:style_emoticons/default/pray.gif) If I have a work party would you come and visit for 20+hours of work! |
tomeric914 |
Feb 26 2012, 09:30 AM
Lo-Fi Version | Time is now: 8th June 2024 - 11:20 AM |
