FS/ !.8 Longblock Engine for sale, SOLD---------------------------- |
jsayre914 |
Feb 27 2012, 02:01 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
I am selling my 1.8 liter engine. I bought it a couple of years ago from another member. It has been stripped of all Fuel injection and Engine Tin. It was running as a daily driver until it began to drop a seat. I will see if I can find a pic of the offending valve seat.
Since I have owned it, I purchased the stock size piston and cylinder kit from AA and installed them, new pushrod tubes, pertronix, one head was rebuilt by Rimco less than 1000 miles ago, it is perfect. The other head was left alone... hence the dropped seat. (If your gettn head work done, DO BOTH SIDES!) I believe I have the original P/Cs that I can trow in to sweetin the deal. Engine is sitting in my garage and the offending head has been removed for inspection. It can all be yours for the low price of..... $200.00 You pick up York PA Attached image(s) |
jsayre914 |
Feb 27 2012, 02:05 PM
The problem
Attached image(s) |
jsayre914 |
Feb 27 2012, 02:06 PM
jsayre914 |
Mar 1 2012, 11:29 AM
Anybody need an engine?? I think this is a great deal cause you get one head that was just rebuilt, with all new valves, guides, etc. You also get a set of Pistons and cylinders that have less than 1000k on them. Fresh rings, and the numbers from the last compression test... The numbers were #1 130 #2 125 #3 65 #4 130 fix the seat and you should be up and runnin quick, but you will need the tin and the induction. (IMG:style_emoticons/default/popcorn[1].gif) |
914runnow |
Mar 1 2012, 08:51 PM
Member Group: Members Posts: 340 Joined: 19-April 04 From: Modesto California Member No.: 1,948 Region Association: None |
(IMG:style_emoticons/default/icon_bump.gif) Anybody need an engine?? I think this is a great deal cause you get one head that was just rebuilt, with all new valves, guides, etc. You also get a set of Pistons and cylinders that have less than 1000k on them. Fresh rings, and the numbers from the last compression test... The numbers were #1 130 #2 125 #3 65 #4 130 fix the seat and you should be up and runnin quick, but you will need the tin and the induction. (IMG:style_emoticons/default/popcorn[1].gif) Ready to Roll on my end..Cep't I am in Colorado...!! (IMG:style_emoticons/default/confused24.gif) |
jsayre914 |
Mar 2 2012, 10:22 AM
Lo-Fi Version | Time is now: 23rd May 2024 - 09:57 AM |
