need a little help with a rocker arm question, rocker assembly |
markyb |
Mar 1 2012, 06:45 PM
Member Group: Members Posts: 100 Joined: 27-November 11 From: Rochester, Michigan Member No.: 13,823 Region Association: None |
Need a little help, is there supposed to be a washer under the nut that holds the rocker shaft to the stud? Also, any suggestions on which Loctite to use on this nut?
Thanks |
mrbubblehead |
Mar 1 2012, 07:44 PM
Twodollardoug Group: Members Posts: 1,155 Joined: 17-December 10 From: calimesa ca. Member No.: 12,492 Region Association: Southern California |
Need a little help, is there supposed to be a washer under the nut that holds the rocker shaft to the stud? Also, any suggestions on which Loctite to use on this nut? Thanks yes, a wavey washer. i am using nylock nuts and no loctite. i would use blue loctite if i had to. |
markyb |
Mar 1 2012, 07:51 PM
excellent idea, someone put standard flat washers on mine, and I would like a little more thread inside the nuts since I had to shim the rocker shafts.
I appreciate the help bubblehead....onward, time to finish this project! |
mrbubblehead |
Mar 1 2012, 08:15 PM
excellent idea, someone put standard flat washers on mine, and I would like a little more thread inside the nuts since I had to shim the rocker shafts. I appreciate the help bubblehead....onward, time to finish this project! |
sean_v8_914 |
Mar 2 2012, 09:48 AM
Chingon 601 Group: Members Posts: 4,011 Joined: 1-February 05 From: San Diego Member No.: 3,541 |
almost everything should have a washer under it. it increases the friction surface area and helps things stay together. also spreads the load of the fastener
Cap'n Krusty |
Mar 2 2012, 10:54 AM
Remember, it's a SEVEN millimeter washer, NOT and EIGHT millimeter washer. OE is a spring washer, BTW.
The Cap'n |
markyb |
Mar 2 2012, 12:55 PM
Thank you, I'm looking for the spring washers, I have a shipment coming from Raby , they might have some old ones for me. I'll wait and finish the job correctly, no hurry, there's still a little road salt on the streets here in the Detroit area, no way my baby is gonna get any of that stuff on her.
Lo-Fi Version | Time is now: 9th June 2024 - 12:49 PM |
