rear wheel bearing stuck, ($*@#(*!@& it! |
seanery |
Sep 15 2004, 02:22 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
any ideas?
passenger side came right out. driver side doesn't seem to move at all. I'm using a 3lb hammer and a 36mm 1/2 drive socket with 8" extension. I have a 5 lb hammer, but no room to swing it under the car. |
fiid |
Sep 15 2004, 02:24 PM
Turbo Megasquirted Subaru Member Group: Members Posts: 2,827 Joined: 7-April 03 From: San Francisco, CA Member No.: 530 Region Association: Northern California |
you could try warming the trailing arm/housing up with a blow troch or a heat gun?
I beat mine out using an old front shock :-) l8r, Fiid. |
d914 |
Sep 15 2004, 02:26 PM
Advanced Member Group: Members Posts: 2,331 Joined: 12-July 03 From: Atlanta, ga Member No.: 904 Region Association: South East States |
slide hammer and pull it. Use a wheel adapter or a piece of steelbolted to three of the studs. I had the same issue. Pounded on it for two days. The side worked beautifully... Not my idea....got it here...
SpecialK |
Sep 15 2004, 02:32 PM
aircraft surgeon Group: Benefactors Posts: 3,211 Joined: 15-March 04 From: Pacific, MO Member No.: 1,797 |
Had the same problem with mine ('73) a couple of years ago. It seemed that the suspension bushings were absorbing too much of the "smack" from the BFH. Ended up pulling the suspension arm and working it on the bench, came right out. Only problem was that since I had it this far apart.... (IMG:style_emoticons/default/wink.gif)
jim912928 |
Sep 15 2004, 04:01 PM
Senior Member Group: Members Posts: 1,485 Joined: 8-January 04 From: Granger, IN Member No.: 1,536 Region Association: Upper MidWest |
Same exact scenario on mine...passenger side came out with a 3lb'r in minutes...drivers side beat beat beat and nothing. I ended up putting the socket on backwords (gave me another 2"), disconnected the shock so I could lower the trailing arm alittle more...then used the BFH and it came out in about 5 bangs.
Doug Leggins |
Sep 15 2004, 04:11 PM
Senior Member Group: Benefactors Posts: 1,358 Joined: 6-February 03 From: Nashville, Indiana Member No.: 261 Region Association: None |
I have a tool that I used. It is 2 aluminum plates and 4 threaded rods with nuts. I used it to pull and push the bearings and bushings off and on when I rebuilt my front and rear suspension. It really is simple and worked great.
you're welcome to use it if you need it. It could also be handy when putting the bearings back in. |
lapuwali |
Sep 15 2004, 05:19 PM
I've never done this (but need to), so I'll ask: is pulling the trailing arms really that much of a big deal? Seems to me that once you have the axles and hubs apart to get at the bearing in the first place, that removing the arm is a pretty minor extra step. The idea of whacking on the thing while under the car with a big hammer while its up on stands doesn't sound too pleasant, nor does it sound like a heathly thing for the trailing arm bushings.
seanery |
Sep 15 2004, 05:57 PM
I thought that same thing, too.
BUT, if those suckers come off I want to put some Mueller bearings in....and I don't have the dough for that right now. |
seanery |
Sep 15 2004, 06:02 PM
I turned the socket around (more contact area on the bearing) and broke out the bigger hammer.
With only a few bruises on my wrist (IMG:style_emoticons/default/smash.gif) it finally came out. |
jim912928 |
Sep 15 2004, 07:57 PM
AMEN!
Lo-Fi Version | Time is now: 31st May 2024 - 05:59 PM |
