Later Passenger Seat Into Early Car, Where's that Thread? |
DBCooper |
Mar 14 2012, 09:04 PM
14's in the 13's with ATTITUDE Group: Members Posts: 3,079 Joined: 25-August 04 From: Dazed and Confused Member No.: 2,618 Region Association: Northern California |
There's a thread showing how to put a later passenger seat into an early car, but I can't find it. It involved welding in a seat adjuster, if I remember correctly. I've searched, no luck, anyone know where it is?
Thanks. |
mepstein |
Mar 14 2012, 09:18 PM
914-6 GT in waiting Group: Members Posts: 19,308 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region |
Should be easy. Weld in the same seat mounts that are on the driver side. Restoration design sells them.
GaroldShaffer |
Mar 14 2012, 09:33 PM
You bought another 914? Group: Benefactors Posts: 7,623 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
Should be easy. Weld in the same seat mounts that are on the driver side. Restoration design sells them. (IMG:style_emoticons/default/agree.gif) plus you will need adjust bracket the mounts on the crossmember. My 70 has a a later passenger seat. I would take some pictures for you, but my car is at Brad Mayeur's shop getting a spring time work done. |
ChrisFoley |
Mar 15 2012, 02:58 AM
I am Tangerine Racing Group: Members Posts: 7,934 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
I've had a design for a bolt in conversion since 1985.
It will be available as a kit in the next month or so. |
DBCooper |
Mar 15 2012, 12:44 PM
Will I be able to afford it, Chris?
I know there was a thread or mention in the thread, even thought I saved the link, now I'll be damned if I can find it. Thanks, gents. |
McMark |
Mar 15 2012, 01:09 PM
Any just bolted the seat rails to the floor in the back and through the box-brace in the front. Nothin' fancy.
ChrisFoley |
Mar 15 2012, 01:56 PM
DBCooper |
Mar 15 2012, 05:39 PM
Any just bolted the seat rails to the floor in the back and through the box-brace in the front. Nothin' fancy. Dude! I thought he was German? (IMG:style_emoticons/default/poke.gif) |
SirAndy |
Mar 15 2012, 06:02 PM
Resident German Group: Admin Posts: 41,671 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Andy just bolted the seat rails to the floor in the back and through the box-brace in the front. Nothin' fancy. Dude! I thought he was German? (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/poke.gif) The seat-rails fit into the rear (fixed) studs, all i had to do is use some flat nuts so the seat can still move. Same in the front, there are already threaded holes in the crossbeam that i used to secure the rails there. No welding or cutting needed. The only thing you can't do with this method is to tilt the seat up/down. (IMG:style_emoticons/default/popcorn[1].gif) |
Lo-Fi Version | Time is now: 3rd June 2024 - 10:58 PM |
