Oil pressure control valve plug, Damn another special tool |
Joe Ricard |
Sep 22 2004, 02:56 PM
CUMONIWANNARACEU Group: Members Posts: 6,811 Joined: 5-January 03 From: Gautier, MS Member No.: 92 |
So it is a triple square cap screw plug. Bigger than 12mm where do I get one of those? Or does someone have a better idea. Shouldn't be too tight If I can get something to fit in it. Nearly bought a big Easyout but decided against it for the moment.
DNHunt |
Sep 22 2004, 03:50 PM
914 Wizard? No way. I got too much to learn. Group: Members Posts: 4,099 Joined: 21-April 03 From: Gig Harbor, WA Member No.: 598 |
Joe
Is this for the yellow car. That Sunday in Gold Bar was fun. If it's the one under cylinder #1 we got it out with tools we had around the house. Memory is kind of fuzzy, (mind you, this looks like a small light at the end of a long tunnel) says try a 3/8" drive in it. I think we used an extension without a socket. The other one is tap it loose with a chisel. Dave |
Dominic |
Sep 22 2004, 04:14 PM
Dominic Group: Members Posts: 992 Joined: 14-January 03 From: Vacaville, CA Member No.: 149 Region Association: Northern California |
The correct tool is a 12 point x 14mm (kind of pricy when I bought mine). I think you can also use the head of a 6mm bolt (10mm 6 point bolt/nuts)?
Joe Ricard |
Sep 22 2004, 08:16 PM
Yea Dave Yellow car. I think this engine is slowly dying. Not because I drive the living piss out of it. (IMG:style_emoticons/default/idea.gif) So not being able to leave well enough alone thought it would be worth a try to see what happens. (IMG:style_emoticons/default/smash.gif)
Got plans to put in my hopped up 2.0L motor real soon. so no worries. 12 pt x 14mm Thats a rare tool. Largest I could find here was 12mm. Going to look at my nuts to see what fits. (shut up) (IMG:style_emoticons/default/slap.gif) |
Joe Ricard |
Sep 23 2004, 07:16 PM
Hey thanks Dave, 3/8" drive universal joint fit right in there. Put a 8" long extension on it and it came right out. Oil pressure is higher now. Will drive it to work and see what it does with warm oil.
Good thing these are not tight and this motor was not put together by a gorilla. |
Lo-Fi Version | Time is now: 6th June 2024 - 01:34 PM |
