WTB 14 pin connector |
timothy_nd28 |
Mar 18 2012, 10:29 PM
Putting my car back together, noticed that the 14 pin wire harness that plugs into the relay board has been cut. I need that connector with 6-8" inches of that wire, so I can solder my wires to it.
Also, looking for the barrel nut that attaches to the throttle cable at the throttle body. |
bdstone914 |
Mar 19 2012, 05:45 AM
bdstone914 Group: Members Posts: 4,535 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
PM sent
Bruce |
IronHillRestorations |
Mar 19 2012, 07:53 AM
I. I. R. C. Group: Members Posts: 6,728 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None |
If you can get about two feet it would be better. Stair step your splices so you don't end up with a huge wad in your harness.
timothy_nd28 |
Mar 19 2012, 08:38 AM
Thanks, excellent advice! (IMG:style_emoticons/default/beerchug.gif)
Drums66 |
Mar 19 2012, 11:40 AM
914 Rudiments Group: Members Posts: 5,321 Joined: 15-January 03 From: Coronado,Cali Member No.: 151 Region Association: Southwest Region |
If you can get about two feet it would be better. Stair step your splices so you don't end up with a huge wad in your harness. .......It would be better (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/bye1.gif) |
falconfp2001 |
Mar 19 2012, 12:09 PM
Pancho Pantera Group: Members Posts: 451 Joined: 5-December 10 From: Downey, CA Member No.: 12,456 Region Association: Southwest Region |
I have an extra wiring harness you can have if you pay the shipping? It also has a working ECU attached.
Frank |
GaroldShaffer |
Mar 19 2012, 12:51 PM
You bought another 914? Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None |
I have an extra wiring harness you can have if you pay the shipping? It also has a working ECU attached. Frank (IMG:style_emoticons/default/hijacked.gif) Frank, If Tim passes on this I would like it, but only if Tim passes. Thanks |
timothy_nd28 |
Mar 19 2012, 01:00 PM
Take it Garold, I'm after the 14 pin connector thats part of the cars wiring harness, not the 12 pin connector attached to the. FI harness
falconfp2001 |
Mar 19 2012, 02:22 PM
Take it Garold, I'm after the 14 pin connector thats part of the cars wiring harness, not the 12 pin connector attached to the. FI harness Oh, then you want this one Attached image(s) |
timothy_nd28 |
Mar 19 2012, 03:06 PM
Yep, that's the one
falconfp2001 |
Mar 19 2012, 11:36 PM
markb |
Mar 20 2012, 12:29 AM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
I have a 14 pin, but it's only got about an inch of wires coming out of it.
naro914 |
Apr 4 2012, 04:16 PM
Losing my mind... Group: Members Posts: 2,476 Joined: 26-May 06 From: Charlotte, NC Member No.: 6,073 Region Association: South East States |
I may have one soon....
I am re-wiring Huey and found that I think I don't need the relay board at all....has a 3.2 with it's own ECU and wire harness. I think I only need 1 or two wires that go from the 14 pin to the 12 pin....if that...in which case I'll use weatherpak connectors and eliminate the relay board. Then again, now that I htink of it...i should have all that from Papa Smurf already. Let me check.... |
JeffBowlsby |
Apr 4 2012, 05:33 PM
914 Wiring Harnesses Group: Members Posts: 8,533 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None |
Patrick MS sells the 14 pin new. PN 911 612 113 05 is for the one with male contacts...call them and they can supply female contacts if thats what you need.
timothy_nd28 |
Apr 4 2012, 07:09 PM
Thanks everyone, I purchased one from a world member. No longer in need for the 14 pin connector
Thanks everyone! |
Lo-Fi Version | Time is now: 7th June 2024 - 06:18 AM |
