2.0 Runners vs 1.7 runners?, 1971 1.7 Megasquirt install |
falconfp2001 |
Mar 20 2012, 03:04 PM
Pancho Pantera Group: Members Posts: 451 Joined: 5-December 10 From: Downey, CA Member No.: 12,456 Region Association: Southwest Region |
I'm working on my MegaSquirt conversion and need some information. I'm going to use the 2.0 intake plenum on my 1.7.
Can I use the 2.o intake runners and just drill for the 4 bolt pattern? Anyone? Thanks Frank |
type47 |
Mar 20 2012, 03:08 PM
you'll have to drill them; 2L and 1.7L runners are different diameter and length so no mix and match
falconfp2001 |
Mar 20 2012, 06:38 PM
Anyone know what the OD is on the 2.0 intake runners?
3d914 |
Mar 20 2012, 07:24 PM
Senior Member Group: Members Posts: 1,275 Joined: 24-September 03 From: Benson, AZ Member No.: 1,191 Region Association: Southwest Region |
falcon,
OD on 2.0 runners is just over 1.5" (39mm) - that's measured w/o my glasses but with a calipers. (IMG:style_emoticons/default/biggrin.gif) IIRC the 2.0 runners should be larger OD (and ID) than the 1.7. Here's a link to my 2.0 MS conversion specs. |
falconfp2001 |
Mar 20 2012, 07:36 PM
falcon, OD on 2.0 runners is just over 1.5" (39mm) - that's measured w/o my glasses but with a calipers. (IMG:style_emoticons/default/biggrin.gif) IIRC the 2.0 runners should be larger OD (and ID) than the 1.7. Here's a link to my 2.0 MS conversion specs. Thanks, that should work for a 1.5 coupler with some HD hose clamps used for turbo couplers. |
JamesM |
Mar 20 2012, 09:22 PM
Senior Member Group: Members Posts: 1,915 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
Why not just use 1.7 injection parts on your 1.7?
falconfp2001 |
Mar 20 2012, 09:34 PM
Why not just use 1.7 injection parts on your 1.7? I'm gonna upgrade the motor in the future and plan to use 3 bolt heads if I can find them. I also think the 2.0 plenum has better flow and it is also better suited to installing an upgraded IAT sensor along with a IAC valve to run MegaSquirt. The TB is not that much bigger and the larger flat fours usually bore out the 2.0 TB for performance running. I should also be able to utilize the 1.7 wiring harness and sensors to work on the 2.0 intake system mounted on a 1.7, in theory. |
Lo-Fi Version | Time is now: 3rd June 2024 - 01:17 AM |
