QUOTE(JamesM @ Mar 20 2012, 08:22 PM)
Why not just use 1.7 injection parts on your 1.7?
I'm gonna upgrade the motor in the future and plan to use 3 bolt heads if I can find them. I also think the 2.0 plenum has better flow and it is also better suited to installing an upgraded IAT sensor along with a IAC valve to run MegaSquirt. The TB is not that much bigger and the larger flat fours usually bore out the 2.0 TB for performance running.
I should also be able to utilize the 1.7 wiring harness and sensors to work on the 2.0 intake system mounted on a 1.7, in theory.
