HELP....... |
HELP....... |
Juniors_914 |
Sep 24 2004, 08:18 PM
dumbass Member Group: Members Posts: 92 Joined: 30-June 04 From: Los Angeles, Ca Member No.: 2,279 |
Today after fixing the electrical problem on my car (thread)..., I go and turn the key to turn on the car and all it does is crank, it doesnt turn on (IMG:style_emoticons/default/mad.gif) , Do you guys have any idea of what can be causing this? or What I should look out for?
TIA -Junior |
McMark |
Sep 24 2004, 08:27 PM
12v to the coil when the ignition is on?
Juniors_914 |
Sep 24 2004, 08:55 PM
QUOTE(markd@mac.com @ Sep 24 2004, 07:27 PM) 12v to the coil when the ignition is on? yes, theres spark comin from the coil -Junior |
seanery |
Sep 24 2004, 09:24 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
fuel pump relay?
Juniors_914 |
Sep 24 2004, 09:52 PM
QUOTE(seanery @ Sep 24 2004, 08:24 PM) fuel pump relay? the pump is working, and i see the fuel flowing through the fuel filter -Junior |
eeyore |
Sep 24 2004, 10:20 PM
Senior Member Group: Members Posts: 889 Joined: 8-January 04 From: meridian, id Member No.: 1,533 Region Association: None |
I tend to forget the trigger points plug and vacuum line on the distributor. Check CHT wire as well.
Juniors_914 |
Sep 24 2004, 10:48 PM
QUOTE(Cloudbuster @ Sep 24 2004, 09:20 PM) I tend to forget the trigger points plug and vacuum line on the distributor. Check CHT wire as well. i checked like 3 times, I even unplugged and plugged it again , and nothin, it just cranks -Junior and the vacuum lines are new This post has been edited by Juniors_914: Sep 24 2004, 10:48 PM |
sj914 |
Sep 24 2004, 10:51 PM
Senior Member Group: Members Posts: 805 Joined: 20-August 03 From: San Jose, CA Member No.: 1,053 |
Spark plugs fouled?
Juniors_914 |
Sep 24 2004, 10:56 PM
QUOTE(sj914 @ Sep 24 2004, 09:51 PM) Spark plugs fouled? havent checked them, but will check them in the morning. thanks for the quick reply you guys.....Any other things I should look out for besides the plugs and plug wires? -Junior |
sj914 |
Sep 24 2004, 11:03 PM
Timing, I've had the distributor turn a little and cause me headaches for a couple days.
Juniors_914 |
Sep 24 2004, 11:46 PM
QUOTE(sj914 @ Sep 24 2004, 10:03 PM) Timing, I've had the distributor turn a little and cause me headaches for a couple days. i was thinking about that. do you or anyone here know of someone in the LA area that can do the timing on my car? and how much is it going to cost me? -Junior |
Juniors_914 |
Sep 25 2004, 06:17 AM
JoeSharpOld |
Sep 25 2004, 06:24 AM
Does it seem cold to you Group: Members Posts: 361 Joined: 29-April 04 From: Camping in Neverland Member No.: 2,001 |
Junior: Where you be hangin?
Joe |
Juniors_914 |
Sep 25 2004, 06:30 AM
QUOTE(Joe Sharp @ Sep 25 2004, 05:24 AM) Junior: Where you be hangin? Joe I live in the f*ed up part of LA....I live in East LA in Boyle Heights to be exact -Junior |
JoeSharpOld |
Sep 25 2004, 06:39 AM
What are you doing up at this time of day, people in you hood dont go to sleep until 4. Hey, check the plug at the triger points if the boot looks like its on the plug can still be unpluged and the car wont start. Bought a teener really cheap because of that. (IMG:style_emoticons/default/biggrin.gif)
Joe |
Juniors_914 |
Sep 25 2004, 06:44 AM
QUOTE(Joe Sharp @ Sep 25 2004, 05:39 AM) What are you doing up at this time of day, people in you hood dont go to sleep until 4. Hey, check the plug at the triger points if the boot looks like its on the plug can still be unpluged and the car wont start. Bought a teener really cheap because of that. (IMG:style_emoticons/default/biggrin.gif) Joe lol I checked that and it is connected, I even pulled the boot back a little to make sure it was pluged -Junior |
JoeSharpOld |
Sep 25 2004, 06:49 AM
Danm. (714) 8478002
Joe |
Juniors_914 |
Sep 25 2004, 07:02 AM
I was hoping it was that or the coil, but the trigger points plug is connected and there is spark at the plugs
-Junior |
JoeSharpOld |
Sep 25 2004, 07:13 AM
Junior: you going to call or what?
Joe |
Juniors_914 |
Sep 26 2004, 06:55 AM
Can't find the timing mark. Is there another way to put the car in timing?
TIA (IMG:style_emoticons/default/unsure.gif) -Junior |
Lo-Fi Version | Time is now: 9th June 2024 - 11:59 PM |
