> What the hell is this?!, AW engine code??
Bob L.
post Mar 30 2012, 02:30 PM
I am currently restoring the D-jet system to my 1.7 and when I got the old intake off I expected to see the engine code on the little flat area underneath, But no.
So I figured I'll look in front of the oel fill tube and I found this
The intake bolt pattern (4) suggests 1.7 heads but the engine code is in the 2.0 location.
What's the deal here?
Thanks
Replies(1 - 15)
post Mar 30 2012, 02:40 PM
Resident German
http://www.thesamba.com/vw/archives/info/engine_letters.php
AW = Type 2
AW 1973/74 1800cc - dual carb.
AW 1975 1800cc - fuel-injected
underthetire
post Mar 30 2012, 02:50 PM
Whats with the broken wire and what was it to?
Bob L.
(IMG:style_emoticons/default/stromberg.gif)
LotusJoe
post Mar 30 2012, 02:51 PM
Europa Twink Driver
WOW Google / Wikipedia says you got a bus engine (IMG:style_emoticons/default/piratenanner.gif)
jcambo7
post Mar 30 2012, 02:54 PM
That sucks... (IMG:style_emoticons/default/sad.gif)
Bob L.
post Mar 30 2012, 02:56 PM
QUOTE(underthetire @ Mar 30 2012, 03:50 PM) *
Good question. I have no idea what it's for.
Anybody...
Bob L.
post Mar 30 2012, 03:01 PM
Should I still try to put the D-jet on? (IMG:style_emoticons/default/confused24.gif)
underthetire
post Mar 30 2012, 03:52 PM
1.8 Bus. D jet will work, had one on my GE bus 2.0 that someone stuck in my car.
euro911
post Mar 30 2012, 04:15 PM
From TUNACAN site
1.8 series (1795cc or 109.5 cu.inches)
Case Prefix ..... Original Application ..... Compression Ratio ........................ Horsepower / Torque
........ AW ................ 1973-75 VW Transporter .................... 7.3:1 ................................ 65hp@4200rpm 92.4 lb-ft@3000rpm
Notes/Comments
'74-'75 models with auto. trans. used L-Jetronic f.i., otherwise dual carbs.
Underpowered for a 914. Underpowered for a bus too (as far as I'm concerned)
SLITS
post Mar 30 2012, 05:58 PM
"This Utah shit is HARSH!"
Wow, you guys are buncha ball busters ..... (IMG:style_emoticons/default/poke.gif)
Dave_Darling
post Mar 30 2012, 06:12 PM
914 Idiot
It would be interesting to see where the dipstick and oil filler are in there. The bus should have a funnel that bolts onto the front-left corner of the engine down almost at the bottom. (That's 914 orientation; it would be right-rear in a Bus.)
The engine did start out as a Bus motor. But it's not exactly difficult to put higher-compression pistons on, or to swap in a 2.0 set, or build just about any Type IV motor on that case....
--DD
Bob L.
post Mar 30 2012, 06:38 PM
Here's the north end of the thing, if that helps figure anything out.
euro911
post Mar 30 2012, 06:58 PM
The dip stick is in the correct place.
Until one tears into the innards, it's kind of hard to say what a PO may have done inside (IMG:style_emoticons/default/confused24.gif)
wingnut86
post Mar 30 2012, 08:03 PM
...boola la boo boola boo...
I still have the single carb and runners off the bus engine out of my original 1970 (ummm, not original motor (IMG:style_emoticons/default/mad.gif) )
There was a box of 1.7 brains/cabling/FIs that came with as well, obviously, they couldn't get them to work with the bus motor they sold me (IMG:style_emoticons/default/biggrin.gif)
Oh, 3 of the injectors were bad (IMG:style_emoticons/default/dry.gif)
type47
post Mar 31 2012, 05:56 AM
Viermeister
QUOTE(underthetire @ Mar 30 2012, 12:50 PM) *
I believe that buses, maybe other Type IV applications, had a flywheel sensor that mechanics could hook up to electronic troubleshooting/maintainence machines. I think that is the sensor.
- Lo-Fi Version Time is now: 31st July 2025 - 04:39 PM
