> Dash lights all went out all of a sudden, fuses are good....
KaptKaos
post Apr 3 2012, 05:56 PM
Family
The other night, all of my dash lights just went out.
Turn, high beam, low fuel, oil, seat belt lights all work. Just the illumination is out.
Fuses are good.
Switch is somewhat suspect, in that I need to jiggle it to get the headlights to pop, but the parking lights come on.
Other than the switch, where should I look? OR have I already answered my own question??
Replies(1 - 7)
falconfp2001
post Apr 3 2012, 07:27 PM
Pancho Pantera
I would trace the wire back to the fuse first. Sometimes the terminals get oxidized and you need to re-establish a connection by pulling the wire and then plugging it back in. As far as I can tell there are no relays associated with dash illumination and the switch or the fuse panel would be your best bet.
914itis
post Apr 3 2012, 08:17 PM
I bet on the switch
Dave_Darling
post Apr 3 2012, 08:25 PM
914 Idiot
Switch or fuse. I know you said the fuses are good, but they can pop and still look good at first. Pull each one out and look at it; if it is really popped the metal part will fall apart when you pull it out of the holder.
--DD
brant
post Apr 3 2012, 09:39 PM
re check you fuse.
I believe its number 9 ?
my hunch...
after you find #9 bad it will keep blowing until you fix the short in your rear bumper liscense tag light
KaptKaos
post Apr 3 2012, 09:40 PM
Family
QUOTE(brant @ Apr 3 2012, 08:39 PM) *
re check you fuse.
my hunch...
That might be true if those were wired up (IMG:style_emoticons/default/lol-2.gif)
brant
post Apr 3 2012, 09:42 PM
QUOTE(KaptKaos @ Apr 3 2012, 08:40 PM) *
re check you fuse.
my hunch...
is it possible that they are shorting to each other or ground because they are not wired up....? maybe the black electrical tape came off causing one of them to be bare?
KaptKaos
post Apr 3 2012, 10:03 PM
Family
QUOTE(brant @ Apr 3 2012, 08:42 PM) *
Good point. Will check that. (IMG:style_emoticons/default/thumb3d.gif)
- Lo-Fi Version Time is now: 11th July 2025 - 04:58 PM
