WTB: Stroker crank, rods and pistons, Show me what you got |
Valy |
Apr 4 2012, 07:29 PM
Senior Member Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
Looking for a matched set of crank , rods and pistons.
Show me what you have and want to ship me for cheap (IMG:style_emoticons/default/biggrin.gif) |
Al Meredith |
Apr 5 2012, 07:19 AM
Senior Member Group: Members Posts: 960 Joined: 4-November 04 From: Atlanta, ga Member No.: 3,061 |
There are 3 different pistons (4 if you count bus) (5 if you count the high compression 1.8L) two rod types (3 if you count bus) and 2 cranks . What combo are you interested .
Valy |
Apr 5 2012, 09:17 AM
There are 3 different pistons (4 if you count bus) (5 if you count the high compression 1.8L) two rod types (3 if you count bus) and 2 cranks . What combo are you interested . As mentioned in the title, I want a stroked crank. Preferably 78mm. This requires pistons with lower compression height and matched rods. All this to avoid insane shims under the cylinders. |
Al Meredith |
Apr 7 2012, 07:14 PM
Sorry, you are correct. I need to read more better. Al
Valy |
Apr 10 2012, 02:11 PM
Jake Raby |
Apr 10 2012, 03:36 PM
Engine Surgeon Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States |
How about an 80mm crank, matching rods and a set of KB 96mm stroker pistons.
I have some in my spring cleaning lot that I need to sell. These are not our components, they were pulled from one of our cores and are good to go. PM me for more details. |
Lo-Fi Version | Time is now: 1st June 2024 - 02:34 AM |
