| stuttgart46 |
Apr 5 2012, 06:35 AM
Member ![]() ![]() Group: Members Posts: 305 Joined: 17-December 07 From: Santa Monica, CA Member No.: 8,474 Region Association: None |
I have tried searching to no avail. I have a '76 that I am trying to get ready to paint and I can't figure out how to remove the front bumper shocks. Do you have to grind off the weld from the support bracket?
I've done this once before but it was about 10 years and a lot of beers ago. Thanks for the help. |
| jim_hoyland |
Apr 5 2012, 07:03 AM
Get that VIN ? ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,028 Joined: 1-May 03 From: Sunset Beach, CA Member No.: 643 Region Association: Southern California
My bumper shock are held by three bolts in the trunk . Welded ? Haven't seen that
| stuttgart46 |
Apr 5 2012, 07:08 AM
There are 3 bolts that hold the support in to place but the support bracket is welded to the bumper shock tube.
| Lennies914 |
Apr 5 2012, 07:15 AM
Slacker ![]() ![]() ![]() Group: Members Posts: 828 Joined: 9-January 10 From: NorCal Member No.: 11,216 Region Association: Northern California |
One bolt under the bumper on each side (right and left) those remove the bumper. Then remove the three bolts on each side (in the trunck) those remove the shocks. On the front there is also a collar that goes around the shock, behind the bumper. The collars have two bolts each.
| mepstein |
Apr 5 2012, 07:20 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,507 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
One bolt under the bumper on each side (right and left) those remove the bumper. Then remove the three bolts on each side (in the trunck) those remove the shocks. On the front there is also a collar that goes around the shock, behind the bumper. The collars have two bolts each. (IMG:style_emoticons/default/agree.gif) 5 minute job once you find the bolts under the rubber bumper cover. I'm pretty sure you need to remove the exhaust to remove the rear bumper supports. |
| stuttgart46 |
Apr 5 2012, 07:36 AM
So the inner bumper (steel part) is bolted to the shocks and you can access the bolts from underneath? Those sneaky Germans. I'll take a look tonight.
Thanks guys. |
| mepstein |
Apr 5 2012, 08:28 AM
So the inner bumper (steel part) is bolted to the shocks and you can access the bolts from underneath? Those sneaky Germans. I'll take a look tonight. Thanks guys. So the inner bumper (steel part) is bolted to the shocks and you can access the bolts from underneath? ---Yes. The correct size socket will take care of it quickly. |
| 76-914 |
Apr 5 2012, 08:33 AM
Repeat Offender & Resident Subaru Antagonist ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,865 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California
getting those bolts off from the bottom is easy. Getting those bastards started back in will get you cussing, though. (IMG:style_emoticons/default/dry.gif)
| jim_hoyland |
Apr 5 2012, 09:04 AM
getting those bolts off from the bottom is easy. Getting those bastards started back in will get you cussing, though. (IMG:style_emoticons/default/dry.gif) (IMG:style_emoticons/default/agree.gif) When (if) you reassemble, attach the three trunk bolts loosely so they you have plenty of play when the bolts under the rubber bumper are installed. I use a long handled hex key to line the holes up. Once the outer bolts are in, go back and tighten the inner 3 bolts. You'll still get some cussing in.... (IMG:style_emoticons/default/smile.gif) |
| stuttgart46 |
Apr 5 2012, 09:09 AM
I'm considering going back with f/g GT bumpers. Those impact bumpers are heavy. I can't decide which way to go with this car. It is the most solid 914 I've ever owned and it's very original but I I've had a couple of GT's and I'd like another.
So, do I repaint this car in orignal black and reassemble it and sell it or do I convert to a GT as I know this car is so solid I'll never find a better candidate? Decisions, decisions. |
| mepstein |
Apr 5 2012, 09:25 AM
Personally, I don't believe in fiberglass bumpers for a street car. We need all the accident protection we can get. I don't like the later bumpers so I would backdate to early. I would use the most solid and rust free car I could for a conversion. If I had given away my red car for free and bought a rust free car for my conversion, I would have been ahead of the game in time and cost. Just my opinion. Good luck, Mark
| mepstein |
Apr 5 2012, 09:27 AM
sfrenck is looking for a rust free car. Doesn't have to be painted. Just an fyi...
| stuttgart46 |
Apr 5 2012, 09:35 AM
Thanks Mark. I agree with you on the F/G bumpers but this car will be doing a lot of track days mostly. The other car I put F/G bumpers was a dedicated track car.
| Dave_Darling |
Apr 5 2012, 05:09 PM
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,326 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California
| mepstein |
Apr 5 2012, 05:22 PM
Personally, I don't believe in fiberglass bumpers for a street car. ... I would backdate to early [bumpers]. The early bumpers provide little if any protection over FG ones IMHO. They're just not that strong. --DD Most of the car is thin sheet steel. The steel bumpers aren't great protection all by themselves but every bit helps in these cars. I was told to keep the spare tire in the front trunk for extra protection. But like I said, It's just my opinion. |
| rfuerst911sc |
Apr 6 2012, 04:35 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,158 Joined: 4-May 06 From: Dahlonega , Georgia Member No.: 5,980 Region Association: South East States |
Get rid of those ugly rubber bumpers and all that weight. Backdate to early bumpers there are plenty out there that can easily be saved by just painting them. Or go fiberglass. I could not believe how heavy these were on my 75 that I backdated. Plus they are ugly (IMG:style_emoticons/default/barf.gif)
Lo-Fi Version | Time is now: 2nd March 2026 - 07:39 PM |
