Engman kit plus a roll cage?, I think it can be worth having the extra weight. |
FourBlades |
Apr 6 2012, 08:57 PM
From Wreck to Rockin Group: Members Posts: 2,055 Joined: 3-December 07 From: Brevard, FL Member No.: 8,414 Region Association: South East States |
I need to decide if I am putting an Engman kit (the passenger area one) into my IMSA car. I weighted the kit at 17 pounds plus maybe a pound or less for welds. I am thinking that it is worth the extra weight to stiffen the car and make it safer in the event of a side impact. I also noticed the the longs under the pads for the roll cage have been flattened noticeably. I think the weight and downward force on the longs is distorting them and causing them to flatten. I'll try to post some pictures of what I mean. Now if I was trying to win a certain competitive division where every pound mattered then I would not do this. But for a car the will run in historic racing where winning is not everything I think it is worth the weight. If I was building a car for lemons or chump car I would probably do it was well for the added safety. What do you all think? John |
Mike Bellis |
Apr 6 2012, 10:57 PM
Resident Electrician Group: Members Posts: 8,345 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None |
Which one will slow you down more?
Chassis flex? Added Weight? |
ChrisFoley |
Apr 7 2012, 06:55 AM
I am Tangerine Racing Group: Members Posts: 7,935 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
My race car has taken some pretty substantial side hits and the cage did everything it was supposed to.
It would take a really bad incident to actually damage my roll cage, and I don't think an Engman kit would make much difference. If the cage is well constructed and well attached to the chassis I see no point in adding thickness to the inner longs and lower firewall. It would be far better to add 17 lbs of strategically placed roll cage tubing. |
brant |
Apr 7 2012, 08:04 AM
914 Wizard Group: Members Posts: 11,640 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
cage alone.
J P Stein |
Apr 7 2012, 09:16 AM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
URY914 |
Apr 7 2012, 04:00 PM
I built the lightest 914 in the history of mankind. Group: Members Posts: 121,070 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None |
Cage only. (IMG:style_emoticons/default/first.gif)
pcar916 |
Apr 7 2012, 04:04 PM
Is that a Lola? Group: Members Posts: 1,523 Joined: 2-June 05 From: Little Rock, AR Member No.: 4,188 Region Association: None |
(IMG:style_emoticons/default/agree.gif) Yup!
Lo-Fi Version | Time is now: 10th June 2024 - 11:32 PM |
