What tool do I use to HOLD the pulley, on a 3.6 engine... |
nine14cats |
Oct 2 2004, 10:38 PM
Bill Pickering -- 914-6 GT aka....Leeloo Group: Members Posts: 2,618 Joined: 10-February 03 From: Campbell, CA Member No.: 287 Region Association: None |
I asked the wrong question before....
What tool holds the crank pulley from moving while I loosen the pulley bolt? Thanks, Bill P. Attached image(s) |
nine14cats |
Oct 3 2004, 12:58 AM
It's been said to try an impact wrench. I'll try that tomorrow.
Any other ideas or someone know the wrench I'm looking for. I have the wrench for my former engine, a 74 2.7 litre, but it doesn't work with the 993. Thanks, Bill P. |
Brando |
Oct 3 2004, 02:31 AM
BUY MY SPARE KIDNEY!!! Group: Members Posts: 3,935 Joined: 29-August 04 From: Santa Ana, CA Member No.: 2,648 Region Association: Southern California |
there's a special wrench that you use, it goes on the top fan-part of the alternator. it's like a C-Shaped opening with two pins that fit into the holes on the front. you then take the alternator bolt off with the shims behind it. Replace the belt, and install the new one.
Steve |
Oct 3 2004, 08:13 PM
914 Guru Group: Members Posts: 5,614 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
I used a flywheel lock.
It slides over one of the trans studs and locks into the starter ring teeth. Steve |
East coaster |
Oct 3 2004, 08:17 PM
Senior Member Group: Members Posts: 1,691 Joined: 28-March 03 From: Millville, NJ Member No.: 487 Region Association: None |
Air wrench worked fine for mine. Is that going into a 914???
Lo-Fi Version | Time is now: 10th June 2024 - 07:28 AM |
