help, brake clips is it correctly installed |
70-914nut |
Apr 11 2012, 03:42 PM
Member Group: Members Posts: 119 Joined: 15-March 11 From: Elizabeth city nc Member No.: 12,826 Region Association: None |
type47 |
Apr 11 2012, 04:16 PM
No, you need this clip: 911.352.951.00_brake_spring
jimkelly |
Apr 11 2012, 04:17 PM
wrong clip maybe ??
Attached image(s) |
Eric_Shea |
Apr 11 2012, 04:24 PM
PMB Performance Group: Admin Posts: 19,278 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Wrong clip definately. Rock Auto probably listed it as the correct clip but... (IMG:style_emoticons/default/biggrin.gif)
70-914nut |
Apr 11 2012, 06:49 PM
are they the same as the rear? I have another set that look like rear clips buy they wont stay in too short. Eria do you have front ones available? Im tired of paying for the wrong ones.
70-914nut |
Apr 12 2012, 02:24 PM
Anyone have a set of front clips laying around? Ill buy them.
maf914 |
Apr 12 2012, 02:40 PM
Not a Guru! Group: Members Posts: 3,049 Joined: 30-April 03 From: Central Florida Member No.: 632 Region Association: None |
I thought the clip looked unusual. I don't have a car handy, but I checked a Haynes manual and the clip it shows is definately different and is what I recall is on my car.
TheCabinetmaker |
Apr 13 2012, 08:07 AM
I drive my car everyday Group: Members Posts: 8,304 Joined: 8-May 03 From: Tulsa, Ok. Member No.: 666 |
I just pulled the front wheels from a car this morning and because of this thread I looked at the clips. Well, I'll be damned! there were the same clips as his. They fit perfectly and hold the pads just fine. Its just a different design. I've seen several of the OE clips that have come apart at the "rivet" point and some that have even broken in half. This looks like a better design than the OE and should last longer. I say use them.
Lo-Fi Version | Time is now: 10th June 2024 - 12:40 PM |
