| rwilner |
Apr 12 2012, 12:44 PM
No Ghosts in the Machine ![]() ![]() ![]() Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
I did a search and found a few threads, but I'm having kind of a hard time getting all the tar off the underside of the relay board to a clean surface.
I was able to chip a lot out. Then I tried a heat gun which really just turned it into goo -- didn't make it easier to remove. Then i soaked it in mineral spirits, which kind of gummed it up...I was hoping it would dissolve it. How can I get the underside pristine? Other chemicals (isopropyl alcohol)? Some kind of media blast? |
| r_towle |
Apr 12 2012, 12:59 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
dry ice, gloves, chisel
| rwilner |
Apr 12 2012, 01:13 PM
| JeffBowlsby |
Apr 12 2012, 01:25 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,385 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Submerge the whole board in Acetone for a week, then scrape off what you can, then soak again for another week. Scrape. Repeat
| rwilner |
Apr 12 2012, 01:33 PM
Submerge the whole board in Acetone for a week, then scrape off what you can, then soak again for another week. Scrape. Repeat (IMG:style_emoticons/default/barf.gif) ok (IMG:style_emoticons/default/biggrin.gif) |
| JeffBowlsby |
Apr 12 2012, 01:57 PM
It werks. (IMG:style_emoticons/default/smile.gif)
| dlee6204 |
Apr 12 2012, 02:07 PM
Howdy ![]() ![]() ![]() ![]() Group: Members Posts: 2,162 Joined: 30-April 06 From: Burnsville, NC Member No.: 5,956 |
I stick my boards in the freezer overnight before I start scraping. It makes it a lot easier to remove.
| Midman914 |
Apr 12 2012, 04:44 PM
Newbie ![]() Group: Members Posts: 9 Joined: 20-December 09 From: Ann Arbor, Michigan Member No.: 11,152 Region Association: Upper MidWest |
Try Xylene, we use it at work to clean our tar based flashing and mastic. Just to be clear, I have not tried this on a relay board, so I am not sure how well it will work, but it is worth a try. I've also found that diesel fuel really eats tar. Most options are going to be messy though. Tar is nasty stuff. Hope this helps.
| ClayPerrine |
Apr 13 2012, 11:38 AM
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 16,568 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille
I just did this the other day.
Heat gun to soften the tar, then a wide bladed putty knife to scrape it off. Do an inch wide segment at a time, and once you get the bulk off, then use a fine putty knife and heat to clean up the rest. |
| Valy |
Apr 13 2012, 12:14 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,677 Joined: 6-April 10 From: Sunnyvale, CA Member No.: 11,573 Region Association: Northern California |
I did a search and found a few threads, but I'm having kind of a hard time getting all the tar off the underside of the relay board to a clean surface. I was able to chip a lot out. Then I tried a heat gun which really just turned it into goo -- didn't make it easier to remove. Then i soaked it in mineral spirits, which kind of gummed it up...I was hoping it would dissolve it. How can I get the underside pristine? Other chemicals (isopropyl alcohol)? Some kind of media blast? Rich, if you can melt the tar with the heat gun, you already resealed it. I know you're trying to get it of and I assume you want to recover the board. But if you can just reseal it then I think you're done (IMG:style_emoticons/default/confused24.gif) |
| rwilner |
Apr 13 2012, 12:16 PM
Rich, if you can melt the tar with the heat gun, you already resealed it. I know you're trying to get it of and I assume you want to recover the board. But if you can just reseal it then I think you're done (IMG:style_emoticons/default/confused24.gif) I'm trying to remove it so I can solder the rivets and fix a couple of non conducting traces. |
| underthetire |
Apr 13 2012, 12:35 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
Goof off seemed to take it off. I heated mine up and got the big stuff out, then rinsed and soaked in goof off. Still a mess, no matter what.
| Valy |
Apr 13 2012, 12:54 PM
Rich, if you can melt the tar with the heat gun, you already resealed it. I know you're trying to get it of and I assume you want to recover the board. But if you can just reseal it then I think you're done (IMG:style_emoticons/default/confused24.gif) I'm trying to remove it so I can solder the rivets and fix a couple of non conducting traces. Hugh (IMG:style_emoticons/default/blink.gif) I didn't know those boards can get so bad. I just thrown away a spare board I had that had all the tar fallen off but the copper traces were fine. The traces are quite thick so brakes in them means they are really gone. I think I have another nice board somewhere. I'm not sure if there are differences between early/late/djet/ljet and not sure which one I have anyway. PM me if you need it and I'll try to dig it up. |
| 02loftsmoor |
Apr 13 2012, 01:02 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 577 Joined: 26-June 11 From: Ft. Worth TX Member No.: 13,243 Region Association: Southwest Region
Berrymans B12 really loosened the tar up, still a mess but the tar is almost a liquid.
I bought a board just to experement seem to work for me Wes |
Lo-Fi Version | Time is now: 8th November 2026 - 12:10 AM |
