> Help me find my short!
AZ914
post Oct 4 2004, 11:28 AM
914 Dumbass
Hey all!
I was driving the teener to Target on Saturday (IMG:style_emoticons/default/driving.gif) when I noticed my RPM guage was sitting at about 1K (I know I was up around 3K). Then I see my temp guage is lower than normal, etc. Then all my guages go dead (except for the speedo of course). The faint glow of the GENERATOR light is on.
Once I get to Target I take a look at the fuse box... FUSE 9 is blown. I figure, no biggie, I haven't changed these fuses in years. So I load a new '8' into FUSE 9. Drive around some more and it shorts out again in about 10-15 miles.
Anyways, just wondering if there are any 'obvious' issues with a blown FUSE 9 on a '75 that anyone has seen before I start testing everything....
Also, anyone have a list of whats on FUSE 9? My Clymers guide wasn't too descriptive....
THX for any help!
Replies(1 - 4)
Rusty
post Oct 4 2004, 02:08 PM
I believe that fuse #9 is backup lights, stop lights and maybe rear turn signals.
I'd check for a short back there in your wiring.
Hope this helps,
Rusty (IMG:style_emoticons/default/smoke.gif)
P.S. Post again if this doesn't sort it out.
TheCabinetmaker
post Oct 4 2004, 02:55 PM
I drive my car everyday
Been there. Turned out to be the wire to the reverse lights were shorting on the top of the heat exchanger.
AZ914
post Oct 4 2004, 03:47 PM
914 Dumbass
Thanks... I'll try to check that tonight... now if I wasn't using reverse.. I wouldn't think it would short.. maybe the blinkers did it...
brp914
post Oct 4 2004, 08:54 PM
Unregistered
Also been there. Stepping on brake would cause alternator light to go bright red, gauges drop to zero. Thought possibly break light switch, but turned out to be wire to engine compartment light hanging down. Good luck with that.
Meanwhile, for purposes of comiseration and amusement. Here's a bad one that happened to me. Plastic rivet holding front side marker light broke while driving. Light dangled by wire thru hole in fender. Fender hole sawed thru insulation causing short. Fuse didn't blow. Instead, wire melted inside loom gaining access to other wires and their fuses. Process snowballed until entire loom for the front of the car was destroyed. Made new loom, but hard because most of color coded wire was gone.
- Lo-Fi Version Time is now: 6th July 2025 - 11:23 AM
