First gear, needed |
J P Stein |
Oct 5 2004, 03:02 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
Anyone have a clue where I can find a 14:37 gear set....or 15:36?....901 of course.
John Kelly |
Oct 5 2004, 03:51 PM
Senior Member Group: Members Posts: 692 Joined: 1-May 03 From: Moclips WA. Member No.: 640 |
Hi JP,
John Walker has a lot of transaxle stuff: JWWORKSHOP@aol.com John www.ghiaspecialties.com |
Joe Bob |
Oct 5 2004, 03:58 PM
Retired admin, banned a few times Group: Members Posts: 17,427 Joined: 24-December 02 From: Boulder CO Member No.: 5 Region Association: None |
I have a stock core sitting in the shop...
propricer |
Oct 5 2004, 04:14 PM
Member Group: Members Posts: 365 Joined: 16-April 04 From: Morgan Hill, CA Member No.: 1,938 |
14:37 is a B and 15:36 is a C ... stock 1st is an A = 11:34
B and C were used as 1st gear in early 911's. |
Joe Bob |
Oct 5 2004, 04:21 PM
My early 911/901 was sold last weekend....never mind.
J P Stein |
Oct 5 2004, 05:59 PM
JW no got.
11:34=35mph 14:37=41mph 15:35=45mph |
TimT |
Oct 5 2004, 06:31 PM
retired Group: Members Posts: 4,033 Joined: 18-February 03 From: Wantagh, NY Member No.: 313 |
I have to go check... I think I only have "A" firsts
TimT |
Oct 5 2004, 06:53 PM
J P Stein |
Oct 6 2004, 01:34 AM
This gear chart shows
11:34 12:34 14:37 15:36....if this C, I'm confused.....no letters on the chart. At any rate, I've found a C....tho I would prefer a B or what ever 14:37 is. (IMG:style_emoticons/default/confused24.gif) |
Bleyseng |
Oct 6 2004, 09:12 AM
Aircooled Baby! Group: Members Posts: 13,035 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
JP, Do you think that the first gear will hold up to screaming around the AX course with that 200hp six you is running?
I would worry that going on and off throttle will snap that first gear shaft off. Geoff |
J P Stein |
Oct 6 2004, 11:48 AM
Dunno, but I intend to find out. (IMG:style_emoticons/default/biggrin.gif)
My stock 1st is so low as to be useless except for starts. I'm gettin' killed on tight corners where the motor falls off the bump.....so I'm trying to get it set up for a useful 1st gear...if/as required. Most of the work is still 2nd gear stuff, but on this last course, having a first gear good to around 40 mph would have been a big help. |
joea9146 |
Oct 6 2004, 12:37 PM
Senior Member Group: Members Posts: 663 Joined: 10-February 03 From: Denver, NC Member No.: 283 Region Association: None |
Jp
Try 914 Limited Inc. Brad Mayeur, 309.694.1797 |
Porsche Rescue |
Oct 6 2004, 03:58 PM
Saving and Enjoying Old Porsches Group: Members Posts: 2,978 Joined: 31-December 02 From: Bend, Oregon Member No.: 64 Region Association: None |
I am about to prove I don't know much about trannys, but what about keeping the stump-puller 1st gear, going lower on 2nd and 3rd (If first is more fragile than the others)?
bondo |
Oct 6 2004, 04:09 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
Second gear is machined right into the mainshaft. You'd have to change it to the mainshaft of the ratio you want, or get a 904 mainshaft that has all the gears interchangable... the 904 mainshaft may not be able to take the extra gear for first (I think it's intended as a 4 speed mainshaft) and it's about as unobtainium as you can get.
I also only have A firsts.. I also have an A mainshaft, but I don't see how that would help. |
Powerman |
Oct 6 2004, 04:19 PM
Newbie Group: Members Posts: 37 Joined: 24-November 03 From: Stafford, VA Member No.: 1,384 |
Try Gary Fairbanks in Norwalk CT
203-866-2466 |
Bleyseng |
Oct 6 2004, 04:32 PM
try Ottos for a repo 904 mainshaft JP and other 1st gears. I think you would be better with a better 2nd and 3rd ratio but bring lots of money to do this.
Geoff |
Porsche Rescue |
Oct 6 2004, 05:40 PM
So, changing 2nd means changing the main shaft. Thanks Royce. Now I know what it means when people talk about a 904 main shaft.
Sounds like you could build real exotic 4 speed autocross box with the 904 piece. If we find one for him, JP might go shopping for a second mortgage on the house! Wonder if an early 912 4 speed might have a useful gear or two inside? |
J P Stein |
Oct 6 2004, 05:45 PM
I've gotten a quote from OTTO's. New C with dogteeth. Not too bad$$.
I'm thinkin' on it. |
bondo |
Oct 6 2004, 05:55 PM
Early 912 trans has AHQX... the A mainshaft wouldn't help at all. H typically gets used as 5th in v8 conversions. (I have an H gear and everything else from 914 and 912 transmissions for sale in the classifieds)
It looks like the real solution is a different R&P (expensive too, and I don't have any). Man, is there anything about these transmissions that isn't expensive? Even saw a shift knob go for $400 on ebay! |
Bleyseng |
Oct 6 2004, 06:17 PM
The gasket set are pretty cheap but that's about it.....
Geoff (IMG:style_emoticons/default/biggrin.gif) |
Lo-Fi Version | Time is now: 6th June 2024 - 10:12 PM |
