Sheridan standard fiberglass kit install, smooth lines |
FL000 |
Apr 17 2012, 09:23 PM
Member Group: Members Posts: 397 Joined: 31-January 12 From: Lancaster, CA Member No.: 14,076 Region Association: Southern California |
I have a Sheridan standard body kit that I am installing; currently in the fitment stage. I plan to use panel bond adhesive to secure them, and I would like the transition from fiberglass panel to stock door/hood/lights/etc to be flush. Any one with experience doing this that can tell me what work I have in store (besides towing it to a body shop)?
Thanks! |
Andyrew |
Apr 17 2012, 09:55 PM
Spooling.... Please wait Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California |
The panels are made to fit on TOP of the standard body panels and literally bolt on. They are not designed to be molded in.
The transition is difficult. I did it on my HPH body panels, but it requires cutting back pretty far and molding them in, aka a LOT of body filler and sanding. Check my progress thread in my sig. |
Elliot Cannon |
Apr 18 2012, 06:15 PM
914 Guru Group: Retired Members Posts: 8,487 Joined: 29-December 06 From: Paso Robles Ca. (Central coast) Member No.: 7,407 Region Association: None |
Don't bond them on. Use Dzus fasteners. It makes working on the car much easier. I could take off both rear fenders and the front end in about 15 minutes. It might be a little more work than bonding but you'll be glad you did.
Attached image(s) |
FL000 |
Apr 18 2012, 09:29 PM
Andrew - thanks for pointing me to your project thread. I need to take my time reading through it all but after a quick skim I can tell how much work you had to put into it. Came out awesome though and I can't believe how fast you cranked it out!
Elliot - I did consider the Dzus fasteners but since this is going to be a street car I opted for something permanent. I like your setup on the front to get the air up into what I presume is a radiator. I have a V8 in mine so I will probably do something similar to get good airfllow into it. |
Mr. 5150 |
Apr 18 2012, 09:37 PM
Newbie Group: Members Posts: 15 Joined: 5-April 12 From: Oxnard, Ca Member No.: 14,338 Region Association: Southern California |
Mine was installed with rivets and spray painted but the results are menacing as I am told. I can't take credit but it does look cool.
Attached thumbnail(s) |
914junkie |
Apr 19 2012, 01:17 AM
Member Group: Members Posts: 167 Joined: 14-December 08 Member No.: 9,848 Region Association: None |
My 73 is a V8 conversion with a Sheridan Body as well. I installed the rear flares and tail with threaded inserts in the sheet metal and small stainless dome top hex head bolts with nylon washers so they snug up tight without cracking the fiberglass. For the front section I made both aluminum and steel brackets that bolt to the body. I put 1/4" rubber mat between the brackets and fiberglass for it to rest on for some cushion. Has worked well for a few years now. It makes it alot easier for both maintenance and repair. ~ Paul (IMG:style_emoticons/default/welder.gif) (IMG:style_emoticons/default/smash.gif)
Lo-Fi Version | Time is now: 29th May 2024 - 02:27 AM |
