 Forum Rules Classified Rules!
> FS: 1975 roller, L80E, front sway, Koni's, been sitting for 10 years, $2k
B2524
post Apr 22 2012, 06:15 PM
It's a sickness.
Up for sale is a 75, paint code L80E light Ivory.
selling as a roller with the following parts removed:
Engine and computer.
Trans and linkage.
Dash has one crack and will be $200 extra.
Top will not be the one in the photos, will be a stock roof.
Steering wheel will be a stock one.
seats will be a nice pair of stock black seats.
no radio
has an air dam.
has Koni's that were installed just before the engine dropped a valve over ten years ago.
has a front sway, no rear.
a tree fell on the hood so I swapped hoods, the dented front fender happened when the motor work was done.
there is a small dent in the right door down low and in the right rear fender.
there is no console.
i need to clean the interior before i can take pictures, it's bad.
figure on replacing the door panels, carpets and some of the other interior stuff.
the rear truck holds water ( i need to drill some holes to drain it...)
i've only looked under the left side and it looks great. i need to move the car so i can jack it up and see under the right side.
asking $2k, it is not in the system so it will come with a bill of sale.
located south of San Jose.
Replies(1 - 5)
B2524
post Apr 22 2012, 06:20 PM
It's a sickness.
the bra is only on to hold the hood down. i didn't have time to adjust the latch so i removed it. i didn't want the hood to get stuck closed.
i'll post pictures of the car without the bra when i have time to install and adjust the latch.
kd
post Apr 22 2012, 11:30 PM
How about the 'blue' one in the back ground?
B2524
post Apr 23 2012, 08:31 AM
It's a sickness.
the blue car is not for sale at the moment.
i have a 1.7 that runs although 2 cylinders are low on compression and i have a spare side shifter that i can offer if someone is looking to complete the car. i would throw them in with the car but i would not try to get the car running.
this will need a complete brake system rebuild, fuel system flush and so forth.
tadink
post Apr 30 2012, 10:01 PM
and the rust? what about the rust?
td
B2524
post May 3 2012, 09:02 AM
It's a sickness.
hell hole isn't too bad, needs a patch.
will get pictures as soon as i pull the motor and tranny.
too many irons in the fire.
- Lo-Fi Version Time is now: 16th June 2024 - 08:52 PM
