Up for sale is a 75, paint code L80E light Ivory.
selling as a roller with the following parts removed:
Engine and computer.
Trans and linkage.
Dash has one crack and will be $200 extra.
Top will not be the one in the photos, will be a stock roof.
Steering wheel will be a stock one.
seats will be a nice pair of stock black seats.
no radio
has an air dam.
has Koni's that were installed just before the engine dropped a valve over ten years ago.
has a front sway, no rear.
a tree fell on the hood so I swapped hoods, the dented front fender happened when the motor work was done.
there is a small dent in the right door down low and in the right rear fender.
there is no console.
i need to clean the interior before i can take pictures, it's bad.
figure on replacing the door panels, carpets and some of the other interior stuff.
the rear truck holds water ( i need to drill some holes to drain it...)
i've only looked under the left side and it looks great. i need to move the car so i can jack it up and see under the right side.
asking $2k, it is not in the system so it will come with a bill of sale.
located south of San Jose.
