FS: 1975 roller, L80E, front sway, Koni's, been sitting for 10 years, $2k |
B2524 |
Apr 22 2012, 06:15 PM
It's a sickness. Group: Members Posts: 72 Joined: 12-November 11 From: Outside Paso Robles CA Member No.: 13,776 Region Association: Northern California |
Up for sale is a 75, paint code L80E light Ivory.
selling as a roller with the following parts removed: Engine and computer. Trans and linkage. Dash has one crack and will be $200 extra. Top will not be the one in the photos, will be a stock roof. Steering wheel will be a stock one. seats will be a nice pair of stock black seats. no radio has an air dam. has Koni's that were installed just before the engine dropped a valve over ten years ago. has a front sway, no rear. a tree fell on the hood so I swapped hoods, the dented front fender happened when the motor work was done. there is a small dent in the right door down low and in the right rear fender. there is no console. i need to clean the interior before i can take pictures, it's bad. figure on replacing the door panels, carpets and some of the other interior stuff. the rear truck holds water ( i need to drill some holes to drain it...) i've only looked under the left side and it looks great. i need to move the car so i can jack it up and see under the right side. asking $2k, it is not in the system so it will come with a bill of sale. located south of San Jose. Attached image(s) |
B2524 |
Apr 22 2012, 06:20 PM
the bra is only on to hold the hood down. i didn't have time to adjust the latch so i removed it. i didn't want the hood to get stuck closed.
i'll post pictures of the car without the bra when i have time to install and adjust the latch. kd |
0396 |
Apr 22 2012, 11:30 PM
Advanced Member Group: Members Posts: 2,046 Joined: 13-October 03 From: L.A. Calif Member No.: 1,245 Region Association: Southern California |
How about the 'blue' one in the back ground?
B2524 |
Apr 23 2012, 08:31 AM
the blue car is not for sale at the moment.
i have a 1.7 that runs although 2 cylinders are low on compression and i have a spare side shifter that i can offer if someone is looking to complete the car. i would throw them in with the car but i would not try to get the car running. this will need a complete brake system rebuild, fuel system flush and so forth. |
tadink |
Apr 30 2012, 10:01 PM
Member Group: Members Posts: 379 Joined: 28-December 09 From: Napa Member No.: 11,181 Region Association: Northern California |
and the rust? what about the rust?
td |
B2524 |
May 3 2012, 09:02 AM
hell hole isn't too bad, needs a patch.
will get pictures as soon as i pull the motor and tranny. too many irons in the fire. |
Lo-Fi Version | Time is now: 25th May 2024 - 03:17 AM |
