> Getting ready for the FFC, Whats on your list?
Engman
post Oct 7 2004, 12:44 PM
Zoisite
Well - here is my list of stuff to finish before the FFC04.
Reinstall side marker lights
Set idle speed (running 1300rpm at idle)
Fix front dash cover
Install new door seals
Check CV bolts
Check Tranny Fluid
Decide what parts to take for swap meet
Install 914 Club sticker (duh)
What has everyone else got left?
I know Sean is still working on brakes and sway bars (IMG:style_emoticons/default/laugh.gif)
M
3 Pages V  1 2 3 >
Replies(1 - 19)
GaroldShaffer
post Oct 7 2004, 12:54 PM
You bought another 914?
Put the Fuchs back on and wash the car (IMG:style_emoticons/default/biggrin.gif)
ArtechnikA
rich herzog
change oil & filter
change air filter
replace spark plugs
ran a can of BG44 through the fuel system
install the radar detector
install the cellphone antenna and car kit
install the bug deflector
Rain-X the windows
jim912928
post Oct 7 2004, 01:14 PM
I've got a list!
1. all 4 wheels brake rebuild (done, in the bleeding process but damn bleeder screws (new) leak around the caliper.
2. pedal cluster build (since I'm putting in a new clutch cable and have the console and stuff out..better do this to).
3. new clutch cable
4. hook up all the hoses for the fresh air vents in front
5. change oil
6. maybe hook up the heater control boxes and hoses in the back?
7. shift rod bushings (all of them). Found the cup one in the back didn't even exist!
I'm going to be busy!
Jim
p.s. fixed my hard to open trunk..i tied a piece of bailer twine to the latch and shoved it down inside the front bumper pad... when I need to open it i just pull...hint hint on the new front trunk cable stuff!
seanery
post Oct 7 2004, 01:24 PM
waiting to rebuild whitey!
ok, here we go....
1. figure out why dustcaps won't fit front rotors
2. hope that replacement hardware shows up so I can install front calipers
3. install front calipers
4. finish building new hard lines (oops-gotta do this before #3)
5. replace pads in rear calipers & set tolerances (hope they clear the 914-6 rotors back there)
6. install hard lines in rear
7. install rear calipers
8. figure out how to get the damn rear sway bar attached to the balls on the shock mounts
9. fit new valence to front of car
10. uh, now it's scary - check inside of case to see if there is any debris
11. if no debris - replace pistons & cylinders with 96s that are in garage
12. get heads back - damn, why so long?
12. install heads & rest of motor stuff
13. put tin on
14. install motor
15. hope tailshifter isn't trashed
16. install tranny (well-with #14)
17. hope all that goes well and the car works
18. finish Engman fuse panel install
19. add J West Fog flash module
20. paint turn signal block off plates
21. install turn signal block off plates
22. install pedal board
23. install new pedals
24. wash the damn car
25. hope it works well
seanery
post Oct 7 2004, 01:26 PM
26. install fuel tank (IMG:style_emoticons/default/headbang.gif)
Engman
post Oct 7 2004, 01:31 PM
Zoisite
Wow Sean. Do we need to add Thursday prior to the FFC as 'Let's all fix Seans car day' ? I remember last year............
Cant help you this weekend as we have company coming in, but might be able to help you later next week. Let me know if there is any help you need.
M
Jeroen
post Oct 7 2004, 01:53 PM
Region Association: Europe
QUOTE(seanery @ Oct 7 2004, 09:26 PM)
Yep, it'll run like crap without it (IMG:style_emoticons/default/biggrin.gif)
rick 918-S
post Oct 7 2004, 01:58 PM
Hey nice rack! -Celette
Oh Ya, I've got a list!
jim912928
post Oct 7 2004, 02:10 PM
man...after seeing all this for once I do feel like I'm overwhelmed! Good luck all of you in worse shape them me! lol
dakotaewing
post Oct 7 2004, 04:00 PM
After you guys get everything else dealt with, make sure you take walkie talkies, so when your on the road, you can comunicate from car to car!!!!
-Thom
ArtechnikA
post Oct 7 2004, 04:08 PM
rich herzog
the packing list is a separate list, and yes, the FRS/GMRS radios are on it. along with camera, film, cellphones, AAA card - and we're not even in a teener !
Engman
post Oct 7 2004, 07:01 PM
Zoisite
(IMG:style_emoticons/default/idea.gif) Kinda sounds like the Alien may make a landing at the FFC! (IMG:style_emoticons/default/mueba.gif) Hope all goes well Rick!
M
rick 918-S
post Oct 7 2004, 07:18 PM
I've been asked to help out with claims in Florida. I think I managed to convince management to give me a stay until Nov. 1 by offering to work claims down there for 6 to 9 weeks. Usually 3 weeks is average for a rep.
jim912928
post Oct 8 2004, 05:35 PM
Progress on my list of to do's:
1. pedal cluster all rebuilt (also stripped and repainted it...POR15'd the area around it)...man the original plastic bushings were really worn!
2. pulled out the clutch cable...about 6" back from the clevis pin thingy the cable was frayed and hanging on by about half of it's strands...I'm lucky
3. brakes are all on and rebuilt..but leaking around the bleeder screws (new ones)...I keep cranking down on them and checking
4. installed all the fresh air vent hoses
Tomorrow is another wrench day!
cnavarro
post Oct 8 2004, 05:46 PM
Cylinder Guru
1. Pulled engine and tranny out of the 912 with the father in law today.
2. Tranny goes to Brad monday for a rebuild.
3. Parking brake gets repaired and brakes re-bled. Maybe take tires around the corner to get balanced.
4. Brad comes with tranny and helps me put it in :-)
5. Attend FFC and show off my 912 that Brad put a week of blood, sweat, and tears into!
Sounds like a plan, no?
Charles Navarro
LN Engineering
http://www.LNengineering.com
Aircooled Precision Performance
qa1142
post Oct 8 2004, 05:57 PM
Whiplash
1) change oil
2) once through - Quick once over
3) Pick what tools to pack
4) pack cloths
5) drop kids at nieghbors
6) turn on radar detector (IMG:style_emoticons/default/mueba.gif)
7) top take and drive, drive, drive
8)drink with you all Friday night! (IMG:style_emoticons/default/beerchug.gif)
GTeener
post Oct 8 2004, 05:59 PM
914 Girl
Only one thing on my list:
Mail out 914 GURL hats as soon as they arrive, so FFC gurls can strut in style (IMG:style_emoticons/default/lol3.gif)
jim912928
post Oct 8 2004, 06:18 PM
Anybody want to start a caravan from those of us up north? Pick a route and pick up others on the way?
GaroldShaffer
post Oct 8 2004, 06:30 PM
Funny you mention that Jim, Julie & I were just talking about that during dinner. We can leave anytime after 4pm, we have to wait for MIL to get here to watch Nathan. What time were you planning on leaving?
edit: what route are you planning to take. We are taking 94 to I65 south to Columbus.
This post has been edited by itsa914: Oct 8 2004, 06:31 PM
3 Pages V  1 2 3 >
- Lo-Fi Version Time is now: 9th June 2026 - 03:42 AM
