Front Sway Bar Removal - How to remove the bar? |
Steve73 |
May 18 2012, 12:50 AM
Photographer/Shade Tree Mechanic Group: Members Posts: 125 Joined: 2-July 11 From: Nashville Member No.: 13,269 Region Association: South East States |
I could use some advice for taking out the bar under the fuel tank. Everything is unbolted but I can't get the rod past the rubber bushings at each end. Do i have to destroy the rubber on one side to get it out? Thanks in advance for your replies.
Steve |
flash914 |
May 18 2012, 01:28 AM
Member Group: Members Posts: 124 Joined: 1-January 11 From: littlerock CA Member No.: 12,554 Region Association: Southern California |
The bushings should have a slit in them. it could be that time and heat has reformed them. look for the cut or make a new one.
Steve73 |
May 18 2012, 09:36 AM
The bushings should have a slit in them. it could be that time and heat has reformed them. look for the cut or make a new one. Ok I see the cut on one side (all I need) how do i take advantage of it? (sorry but this is the one thing on dismantling this car that has stumped me. Got to get it finished and to the junk yard before my wife will let me bring in the 914 I just bought. |
ChrisFoley |
May 18 2012, 11:06 AM
I am Tangerine Racing Group: Members Posts: 7,935 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None |
You need to pop the mounting bracket on one side off of the rubber.
Then you can pry open the rubber to remove it. |
Steve73 |
May 18 2012, 02:28 PM
You need to pop the mounting bracket on one side off of the rubber. Then you can pry open the rubber to remove it. Racer I bolted the mount holding the bar back to the car, i grabbed at the rubber with needle nose pliers till i had enough material gone so i could spray lubricant into the void. The rubber gasket comes out towards the car body. I would think that a small punch would push it out. Thanks for everyone's help. |
Lo-Fi Version | Time is now: 11th June 2024 - 06:18 AM |
