audio_file |
Member ![]() ![]() Group: Members Posts: 295 Joined: 6-August 11 From: Everett, Wa Member No.: 13,409 Region Association: Pacific Northwest ![]() |
I searched! I even tried to resurrect an old thread but it didn't get much attention, so I'll start another...
I bought a 205aa distributor (1974 1.8 dizzy) for my 2.0 with dual webers (it has an 009 now), and I'm not sure about the vacuum connections. The vacuum can on the 205 has two vac ports, as I understand it, one for advance and one for retard ( (IMG:style_emoticons/default/drooley.gif) (IMG:style_emoticons/default/biggrin.gif) ). What do I do with the retard side, use it or plug it? Where would the retard side plug into? Will this operate as well as an SVDA (assuming both have petronix installed), or should I re-sell this 205 and pick one of those up instead? Finally, do I need to use the vacuum from both carbs, or will one suffice? TIA Chris |
audio_file |
Anyone? Bueller? Bueller? (IMG:style_emoticons/default/icon_bump.gif)
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,249 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
i need to put a 205 in the green car. i tried 205 +distributor +carburetor and got 3 pages of threads. i can't devote hours sifting thru them. should i use the text contain option rather than title search?
audio_file |
i need to put a 205 in the green car. i tried 205 +distributor +carburetor and got 3 pages of threads. i can't devote hours sifting thru them. should i use the text contain option rather than title search? The search function will dismiss the "205" part, so you're getting everything containing distributor and carburetor... I used +weber +distributor, and you can limit it further by searching titles only. What specifically did you need to know? |
914itis |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,892 Joined: 9-October 10 From: New York City Member No.: 12,256 Region Association: North East States ![]() |
I don't think you need any vacuum for carbs. You can simply leave them unplug or remove the can.
rhodyguy |
perfect. thanks paul.
k |
audio_file |
But, the car will run be more smoothly, and more efficiently with the vacuum, that's the whole point of using the 205 instead of a 009. Which carbs are you using?
r_towle |
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States ![]() ![]() |
For advance, drill out the ports on the carbs for vacuum, tie them all together into a single line, then tie that to the advance port.
Don't use the retard port, leave it open and unplugged to the atmosphere. Set timing at 3500 rims to ensure you are dealing with full advance when timing it. You may need to mark your fan and housing, or use a newer timing light that can be programmed for 27 degrees advance. The advance vacuum canister just brings on the advance sooner than the normal weights do it, so it's a smoother ramp up from a stop light.. Retard is purely for emissions and seeing as you have carbs, you are not worried about emissions. Rich |
audio_file |
For advance, drill out the ports on the carbs for vacuum, tie them all together into a single line, then tie that to the advance port. Don't use the retard port, leave it open and unplugged to the atmosphere. Set timing at 3500 rims to ensure you are dealing with full advance when timing it. You may need to mark your fan and housing, or use a newer timing light that can be programmed for 27 degrees advance. The advance vacuum canister just brings on the advance sooner than the normal weights do it, so it's a smoother ramp up from a stop light.. Retard is purely for emissions and seeing as you have carbs, you are not worried about emissions. Rich ^^This, except if he's running webers, the port on the carbs is already there, just with a tiny screw to cap if off when not in use... No drilling required. And, depending on which 205 he's using, the maximum advance can be as high as 29-32 at 3400 RPM. |
rhodyguy |
where did you find the dif listing for the l-jet distributors? the exploded parts diagram in the AA cat, p.212, all the listings start 022 905 205 with the dif being the ending letters. F, AB, H, P, no letters, and A with the AB listed as the only one for 1.8 l-jet with a specific ECU#. the rest are d-jet for assorted 1.7 and 2.0s with specific engine serial number ranges. i see where it would be easy to be confused with the generic '205' term. the AB seems to be crucial. i'm in the 'putting away' mode and i guess i'll have to open some boxes.
k |
audio_file |
where did you find the dif listing for the l-jet distributors? the exploded parts diagram in the AA cat, p.212, all the listings start 022 905 205 with the dif being the ending letters. F, AB, H, P, no letters, and A with the AB listed as the only one for 1.8 l-jet with a specific ECU#. the rest are d-jet for assorted 1.7 and 2.0s with specific engine serial number ranges. i see where it would be easy to be confused with the generic '205' term. the AB seems to be crucial. i'm in the 'putting away' mode and i guess i'll have to open some boxes. k Found this chart here, during a search for the info I was originally looking for when I posted this thread: (IMG:http://www.914world.com/bbs2/uploads_offsite/i219.photobucket.com-13409-1338133373.1.jpg) |
rhodyguy |
wow!! cool chart. i don't know where you found it but it should be in the 'originality forum' if not already there. the AA and AB have the same specs. i wonder if the dif is being for a 74' L-jet system vs 75-76'.
k |
audio_file |
Found it here: (post 6)
http://www.914world.com/bbs2/index.php?sho...=advance++chart |
brant |
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,020 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains ![]() ![]() ![]() |
I've owned about 6 sets of 4cylinder idf's
only 1 of them had the vacuum ports I assume that was a "later" model of carb but don't know for sure. the majority don't have the vacuum ports made in from the factory. Nice chart! |
rhodyguy |
none of the weber IDF series carbs i've owned have had the provision for vacuum advance lines. i'm sure there are some but very application specific.
k |
audio_file |
none of the weber IDF series carbs i've owned have had the provision for vacuum advance lines. i'm sure there are some but very application specific. k Weird. I checked mine (Spanish made 40's) and it was there on both, here: (IMG:http://www.914world.com/bbs2/uploads_offsite/i219.photobucket.com-13409-1338137171.1.jpg) |
rhodyguy |
i just looked at some italian 40s. screws are there. you learn something new everyday, hopefully. this is turning into a very informative thread.
k |
audio_file |
Man I searched and searched before I started a new thread, it amazing whats already out there that just needs to be "re-discovered" ... Here, the bird site, the samba... It's overwhelming really! Glad to share what I come across!
(IMG:style_emoticons/default/beerchug.gif) Chris |
r_towle |
Some webers are drilled, some are not, all of them have the bung that can be drilled.
Rich |
Grelber |
Insert favorite Don Rickles joke here. ![]() ![]() ![]() Group: Members Posts: 690 Joined: 30-May 06 From: McKinney, Texas Member No.: 6,107 Region Association: Southwest Region ![]() |
I have a 2.0L w/ Weber 40's and the 205D dizzy. The vacuum can is on but isn't hooked up and it runs great.
Lo-Fi Version | Time is now: 31st July 2025 - 01:10 PM |
