Fuel Tank Marine Clean Treatment, What's the best way to cover the openings after filling? |
Nozzle |
May 22 2012, 03:39 PM
Member Group: Members Posts: 158 Joined: 6-November 08 From: Lexington Park, Maryland Member No.: 9,725 Region Association: MidAtlantic Region |
For the folks that have done the Marine Clean treatment to their fuel tank, what did you use to cover the top and bottom openings after poring in the cleaning solution and water?
Thanks, John |
tod914 |
May 22 2012, 04:12 PM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
You can use Gorrila tape. The solution might stain the paint abit. If you don't want to touch up the paint, be sure to have the garden hose handy.
r3dplanet |
May 22 2012, 05:51 PM
Senior Member Group: Members Posts: 679 Joined: 3-September 05 From: Portland, Oregon Member No.: 4,741 Region Association: None |
I recently did mine. Gorilla tape didn't work. Neither did aluminum tape, duct tape, etc. On the two output ports, I used black rubber plugs I picked up from Ace Hardware from the fasteners section. Just shoved them in as hard I could and this worked quite well. On the large openings up top, I used something else I found at the hardware store in the plumbing section. I don't know the name of it but its sort of a rubber doughnut sandwiched in plastic with a bolt and wingnut through the center. Center the doughnut, tighten the wing nut, and it expands the rubber to form a very tight seal. So tight in fact that you could potentially warp the metal. Be careful. Measure the holes first. You'll need two.
tod914 |
May 22 2012, 06:44 PM
On the metal pipes I left on a small section of fuel line and plugged it. If the tape goes onto a dry surface, it will work fine. I only used the tape on the top openings of the tank. Eventually it will fail, but should stay on there long enough to do the job.
Krieger |
May 22 2012, 07:26 PM
Advanced Member Group: Members Posts: 4,727 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None |
Two flat pieces of aluminum 1/8" plate with holes drilled for the bolts. Then use the old gaskets. Plugged fuel line for the bottom/lines out.
shuie |
May 22 2012, 07:52 PM
Member Group: Members Posts: 352 Joined: 17-May 04 From: baton rouge, la Member No.: 2,075 |
Is Marine Clean included in the POR tank restoration kit?
ConeDodger |
May 22 2012, 08:51 PM
Apex killer! Group: Members Posts: 23,612 Joined: 31-December 04 From: Tahoe Area Member No.: 3,380 Region Association: Northern California |
porschefile2010 |
May 22 2012, 10:45 PM
Member Group: Members Posts: 228 Joined: 26-May 11 From: Whangaparaoa, New Zealand Member No.: 13,118 Region Association: Australia and New Zealand |
I've done it. I think Krieger(Andy) has the answer. Tape eventually came unstuck. It's good if you can make sure of a really good seal so you can get on with the cleaning without worrying about whether the tape will stick or not.
Also when you come to do the POR make sure the gauze sock is out. Good luck. It's an amazing product. |
Nozzle |
May 23 2012, 08:08 AM
Thanks for all the good ideas folks. I think I'll try the plate and stock gasket idea and see how that works.
JStroud |
May 23 2012, 08:20 AM
Senior Member Group: Members Posts: 1,463 Joined: 15-January 11 From: Galt, California Member No.: 12,594 Region Association: Northern California |
On the large openings up top, I used something else I found at the hardware store in the plumbing section. I don't know the name of it but its sort of a rubber doughnut sandwiched in plastic with a bolt and wingnut through the center. Center the doughnut, tighten the wing nut, and it expands the rubber to form a very tight seal. Those are called test plugs, used for temporarily sealing plumbing pipe to test for leaks. Seems these would work great and be easier than making a plate. Jeff |
PanelBilly |
Jun 1 2012, 08:19 PM
914 Guru Group: Members Posts: 5,817 Joined: 23-July 06 From: Kent, Wa Member No.: 6,488 Region Association: Pacific Northwest |
I used the test plugs on mine and some small black rubber plugs in the 2 fuel line holes. Worked great. Still have the test plugs. Don't know what else they'll ever be good for!
kwlane |
Jun 1 2012, 11:29 PM
Member Group: Members Posts: 91 Joined: 9-February 12 From: Newcastle, WA Member No.: 14,108 Region Association: Pacific Northwest |
I made plates out of 1/4 plywood has sitting around and used gaskets from tank. That worked pretty well, little leakage but not a lot. |
Lo-Fi Version | Time is now: 8th June 2024 - 03:33 PM |
