what's the story with this steering wheel, #914 347 805 10 |
rhodyguy |
May 29 2012, 01:16 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,090 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
the back side of the center is weird and there is a little spring with non ferrous contact point on the inside end coming out the front of the center portion. then i found another one with the # 914 347 805 11. wasup?
k Attached image(s) |
r_towle |
May 29 2012, 01:23 PM
Custom Member Group: Members Posts: 24,588 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States |
cant see the back, but that is spring is a horn contact.
rich |
markb |
May 29 2012, 01:29 PM
914less :( Group: Members Posts: 5,449 Joined: 22-January 03 From: Nipomo, CA Member No.: 180 Region Association: Central California |
70/71 wheel
rhodyguy |
May 29 2012, 01:52 PM
back shot. there are no threaded holes to attach anything to. there are 6 small threaded holes in the center section.
rhodyguy |
May 29 2012, 01:55 PM
oops the holes are threaded. where's the edit button?
k |
carr914 |
May 29 2012, 02:15 PM
Racer from Birth Group: Members Posts: 119,001 Joined: 2-February 04 From: Tampa,FL Member No.: 1,623 Region Association: South East States |
If you want to sell it let me know please
T.C. |
OU8AVW |
May 29 2012, 02:19 PM
Yacht Rigger Group: Members Posts: 1,803 Joined: 1-October 08 From: Granbury, TX Member No.: 9,601 Region Association: Southwest Region |
T.C.'s radar went off! That may be something special (IMG:style_emoticons/default/biggrin.gif)
scotty b |
May 29 2012, 02:28 PM
rust free you say ? Group: Members Posts: 16,375 Joined: 7-January 05 From: richmond, Va. Member No.: 3,419 Region Association: None |
it's amazing what google will tell you with the first search result......................
(IMG:style_emoticons/default/stirthepot.gif) (IMG:style_emoticons/default/poke.gif) (IMG:style_emoticons/default/slap.gif) |
seanery |
May 29 2012, 02:46 PM
waiting to rebuild whitey! Group: Retired Admin Posts: 15,854 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
in regards to 911 RS Steering wheels
QUOTE Along with the most common part # 806 10, an RS could have come with 805 11 and even 805 10 (which is actually an 914-4 wheel but it has the correct hub with countersunk and tapped holes). The part # on the box of my NOS wheel you mention is a mid to late 70's part # that superceedes the previous PET part #. The RSR wheels I have seen are 803 10, which is a hard rubber core wheel with felt and padding covered with leather. |
gms |
May 29 2012, 02:54 PM
Advanced Member Group: Members Posts: 2,695 Joined: 12-March 04 From: Chicagoland Member No.: 1,785 Region Association: Upper MidWest |
the back side of the center is weird and there is a little spring with non ferrous contact point on the inside end coming out the front of the center portion. then i found another one with the # 914 347 805 11. wasup? k I added a bunch of info on the different 914 wheels, read this thread and you will know the differences. Early 911S Registry |
rhodyguy |
May 29 2012, 02:58 PM
or digging out the old AA catalog. shows #914 347 805 11 Leather Steering wheel 1972 914-6. the one ending in 805 10 isn't listed and the #s for 4 early cars end 090 10 and 091 10.
Attached image(s) |
Gustl |
May 29 2012, 03:22 PM
914 enthusiast & historian Group: Members Posts: 11,523 Joined: 16-June 04 From: TIROL / Austria Member No.: 2,212 Region Association: Austria |
back shot. there are no threaded holes to attach anything to. there are 6 small threaded holes in the center section. as you learned above, this is a 1970/71 leather steering wheel for the 914-4 therefore you need to attach this black thing (sorry ... don't know its name): and there are 4 little screws to mount it on the steering wheel - I put red circles around the mounting holes: when using it this way, the horn contact is made with the little brown cable when using it on a 914-6 you will need the horn contact with the spring (as shown in your post); but ... originally it should look like this: |
914Sixer |
May 29 2012, 07:11 PM
914 Guru Group: Members Posts: 8,903 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region |
Most of the early wheels 70/71 were drilled for BOTH the 4 and 6. The counter sunk holes allow you to use the 911 cancelling plate used by the -6. Four circled holes are for mounting the -4 plate and using the long horn button as shown above. Then they could stamp what ever number they needed in the wheel.
Lo-Fi Version | Time is now: 8th June 2024 - 08:14 AM |
