newbie headlight adjustment, headlight cover is dropping lower on one side |
oooty21 |
Jun 1 2012, 09:27 AM
Newbie Group: Members Posts: 7 Joined: 1-June 12 From: los angeles Member No.: 14,505 Region Association: None |
New to the 914 World, I will be posting a lot of questions. I just purchased my first 914, and it is going to need a lot of love. I am sure this has been posted in the past, but was unable to find it, so here it is: how do I adjust the front headlights, as one of them is trying to dig itself back under the hood. On my old Miata you could adjust the sinking headlight by gently pulling on the cover, but this one is at least an inch off, leaving a huge gap between the hood and the painted headlight cover. All help is greatly appreciated (IMG:style_emoticons/default/smile.gif)
luskesq |
Jun 1 2012, 09:37 AM
Member Group: Members Posts: 276 Joined: 24-October 10 From: Fresno, CA Member No.: 12,303 Region Association: Central California |
Been a while since I played with mine but with a '70 there are three screws (allen head) inside the wheel well and comporable three inside the trunk (inside protective cover). Loosen and adjust to fit.
Good luck, Keith |
oooty21 |
Jun 1 2012, 09:50 AM
Thank you Keith, I will take a look at these this evening
ClayPerrine |
Jun 1 2012, 11:22 AM
Life's been good to me so far..... Group: Admin Posts: 15,519 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
1. Turn the headlights on, then turn them back off. That puts the headlight motor in the "down" position.
2. Remove the relay that you find under the black plastic cover in the front trunk. This will let you keep your fingers if you accidentally move the motor position. 3. Loosen the jamb nut on the headlight stop, located on the back wall of the headlight bucket next to the motor, and screw the slotted screw all the way in until it matches flush with the jamb nut. 4. Loosen the three screws on the inboard headlight pivot, located in the front trunk. 5. Loosen the 2 screws on the outboard headlight pivot, located under the fender. 6. Move the headlight assembly around until it fits the opening correctly. Hold it there and have a helper tighten all of the pivot bracket bolts. 7. Put the relay back in, and turn the lights on and off a couple of times. Verify that the headlight ends up adjusted correctly when closed. 8. Turn the headlights on. 9. Adjust the headlight stop until it makes contact with the bracket on the bottom of the headlight pivot arm. Make sure it is touching, but not pulling on the bracket. Then tighten the jamb nut. 10. Turn off headlights. Now go have a beer. (IMG:style_emoticons/default/beer3.gif) (IMG:style_emoticons/default/beerchug.gif) (IMG:style_emoticons/default/beer.gif) |
oooty21 |
Jun 1 2012, 11:42 AM
Thank you Clay
falconfp2001 |
Jun 1 2012, 12:08 PM
Pancho Pantera Group: Members Posts: 451 Joined: 5-December 10 From: Downey, CA Member No.: 12,456 Region Association: Southwest Region |
oooty21 |
Jun 1 2012, 06:49 PM
Pictures are worth a 1000 words; thank you
oooty21 |
Jun 1 2012, 06:53 PM
It turns out I am missing one of the adjusting bolts...looks like it will be an easy fix after all, thank you all for your help
76-914 |
Jun 1 2012, 07:17 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
Look again. I'll bet the hole is stripped out.
Lo-Fi Version | Time is now: 9th June 2024 - 06:46 AM |
