center console, how to attach the center console |
oooty21 |
Jun 1 2012, 09:32 AM
Newbie Group: Members Posts: 7 Joined: 1-June 12 From: los angeles Member No.: 14,505 Region Association: None |
The center console is held by gravity only at this point. Does anyone have pictures on how it is supposed to be mounted properly to the car?
Thank you (IMG:style_emoticons/default/smile.gif) |
SLITS |
Jun 1 2012, 10:20 AM
No pics ...
Center bracket has two screws in bottom plate to tunnel metal Back end has a "U" shaped bracket with a single screw into the tunnel sheet metal Top has a "U" shaped bracket that screws to the sides and then two screws in it to the bottom side of the cowl. |
rwilner |
Jun 1 2012, 11:04 AM
No Ghosts in the Machine Group: Members Posts: 953 Joined: 30-March 10 From: Boston, MA Member No.: 11,530 Region Association: North East States |
Mine's attached with only the U bracket at the top (right behind the gauge face) and that holds it in place very well.
falconfp2001 |
Jun 1 2012, 12:48 PM
Pancho Pantera Group: Members Posts: 451 Joined: 5-December 10 From: Downey, CA Member No.: 12,456 Region Association: Southwest Region |
76-914 |
Jun 1 2012, 02:47 PM
Repeat Offender & Resident Subaru Antagonist Group: Members Posts: 13,509 Joined: 23-January 09 From: Temecula, CA Member No.: 9,964 Region Association: Southern California |
No pics ... Center bracket has two screws in bottom plate to tunnel metal Back end has a "U" shaped bracket with a single screw into the tunnel sheet metal Top has a "U" shaped bracket that screws to the sides and then two screws in it to the bottom side of the cowl. (IMG:style_emoticons/default/agree.gif) |
Steve |
Jun 1 2012, 08:15 PM
914 Guru Group: Members Posts: 5,613 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California |
Its rocket science we would need to bring in NASA!! Just kidding as already said there is two sheet metal screws that mount the bracket to the upper body and two screws that mount the bracket to the center console. There is also another bracket that mounts the console to the center tunnel. I took mine out for more leg room, otherwise I would take pictures.
Lo-Fi Version | Time is now: 8th June 2024 - 01:24 PM |
